Conservation of energy: Conceptual question
In summary, the twin who is moving faster (Twin A) would consume more energy due to the greater friction they encounter.
Neha Siddhartha
Two identical twins, A & B, are riding identical bikes up the same hill, both at constant speed. Twin A takes 20 seconds to climb the hill, while twin B takes 40 seconds.
a) Neglecting all forms of friction, which twin consumes more energy?
b) With friction, which twin consumes more energy?
Kinetic E = ½mv[2]
Gravitational Potential E = mgh
a) Intuitively, I know that both consume the same amount of energy.
Their gain in potential energy is the same, as they are going up the same hill so h, or height, must be the sa
me.
However, I do not understand how to explain it using the equations. Twin A would have 4x the kinetic energy of Twin B, so the kinetic E applied does not equal the potential E gained. (½mv[2] ≠ mgh).
So, should I instead think of the total energy of each biker?:
Total E consumed = ½mv[2] + mgh
b) The biker going faster (Twin A) would consume more energy. I think that with a greater velocity they will encounter greater friction. (Is this correct?) My professor said friction is just random or nondirectional kinetic energy. How can I explain this mathematically with just the equations given?
Welcome to the PF.
I don't think you mean to use the word "friction", since it's impossible to "climb a hill" without friction with the ground. I think you mean "air resistance", right? Then the answer to part (b) is more straightforward. :smile:
Hint: twin "B" must be taking the long way around, as he travels twice as far as twin "A". What's that suggest as far as friction is concerned (not air but tire-to-ground)?
I disagree with this hint.
The phrase "constant speed" indicates that each twin stays at the same speed she started with. It does not indicate that both twins travel at the same speed as each other. Accordingly, it is entirely possible that both twins are following the same route up the hill. That is the assumption I make when reading the problem -- that the route is the same and one twin is moving twice as fast as the other. [That said, the standard rule of test taking applies -- if you have to make assumptions, state them clearly up front and proceed with the rest of the problem. That way you are likely to get credit even if your interpretation of the problem disagrees with the instructor's]
Likes Neha Siddhartha, CWatters and berkeman
Neha - Think about the work done in each case. For example what is the equation for the work done against gravity? Friction? I think you might be over complicating the answer.
Note it only mentions friction not air resistance/drag.
On second thoughts I agree with you. Thanks.
My professor said that changes in E do work. In (a) the velocity and therefore the kinetic E of both twins stay the same, so you only look at the gain in gravitational potential energy (E = mgh). Therefore, to balance this identical gain in E, they must consume the same amount of E.
(b) represents the real world version, where we lose E to friction.
My professor defines air friction as heat, which is random kinetic energy. So does a greater directed kinetic E translate to greater amount of heat?
Also, what is the equation that I should be using to define friction?
Thank you! :)
For part b, friction between the tire and ground will be what - the same or different? (Hint: use coefficient of kinetic friction, generally assumed independent of speed).
Then there is the other friction - air movement - see post 2!
Thank you! :)
Air friction force: F = kv2 typically assumed, v = velocity.
Ask your teacher if you should include air resistance in pary b or not.
Friction is normally considered independent of speed. Air resistance does depend on speed.
FAQ: Conservation of energy: Conceptual question
What is the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, but can only be transformed from one form to another. In other words, the total energy of a closed system remains constant over time.
How does the law of conservation of energy apply to everyday life?
The law of conservation of energy applies to everyday life in many ways. For example, when we turn on a light, the electrical energy is converted into light and heat energy. When we ride a bike, the chemical energy in our body is converted into kinetic energy to move the bike.
Can energy be lost or wasted?
No, according to the law of conservation of energy, energy cannot be lost or wasted. It can only be transformed into a different form. However, some forms of energy may be more useful or efficient than others.
What types of energy can be conserved?
All forms of energy can be conserved, including kinetic energy, potential energy, thermal energy, chemical energy, and electromagnetic energy. However, the most common forms of energy that are conserved in daily life are mechanical, thermal, and electrical energy.
How is the law of conservation of energy related to the first law of thermodynamics?
The first law of thermodynamics is essentially a restatement of the law of conservation of energy. It states that energy cannot be created or destroyed, but can only be transformed or transferred from one form to another. This law is often used in thermodynamics to analyze energy systems and processes.
