Conservation of energy for a series of elastic collisions
The discussion centers on the calculation of the speed of a block after multiple elastic collisions, with the initial formula presented as V_n=(2e)^n*v_0. However, participants challenge this formula, asserting it is only accurate for the first collision. The correct expression for the speed after the nth collision is proposed as V_n=2e(1-2e)^{n-1}*v_0, referencing specific equations from a textbook. Additionally, the total distance traveled by the block is derived using conservation of energy principles, leading to a formula that incorporates the initial speed and the coefficient of restitution. The conversation highlights the importance of accurately applying principles of physics to derive correct formulas for elastic collisions.
Andrew1235
A link to the problem: https://i.stack.imgur.com/tDhbm.png
A link to the solution: https://i.stack.imgur.com/h5s1g.png
The speed of the block after the nth collision is
$$ V_n=(2e)^n*v_0 $$
By conservation of energy the block travels a distance $$V_n^2/(2ug)$$ on the nth bounce. So the total distance is
$$ d=1/(2ug)∗(v_0^2+(2ev_0)^2...) $$
$$ d=1/(2ug)∗(v_0^2/(1−4e^2)) $$
$$ d=1/(2ug)∗(v_0^2∗M^2/(M^2−4m^2)) $$
Can someone explain why this is incorrect?
I don't believe the following is correct (other than for n = 1).
Can you explain how you got this?
According to 5.155 and 5.156, it should be
$$ V_n=2e(1-2e)^{n-1}*v_0 $$
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
