Conservation of energy in a moving frame
In summary, the conversation discusses the conservation of energy in a moving frame of reference and the apparent loss of energy in a ball Earth system. The expert explains that energy is always conserved, even in collisions and a moving frame, and that potential energy is relative to the mass of both objects. The expert also suggests testing one's intuition by calculating the amount of kinetic energy gained by the Earth and lost by the ball to see if it matches one's intuition.
Electric to be
152
I know a similar question has been asked but I'm still kind of stumped.
Imagine the Earth on the left and a small mass to it's right separated by some distance h.
You are in the frame of reference where the Earth and the small mass are moving to your right at some speed v.
So, both the Earth and the ball have some initial kinetic energy (1/2)(respective mass)v^2 and the ball Earth system will lose a potential energy of mgh as they come together.
So the Earth won't gain any significant energy since it is so massive but the ball appear to lose energy since it is accelerated to the left. How is energy conserved if the potential energy is gone and the ball Earth system appears to actually lose energy?
My only possible reasoning is that potential energy is somehow relative? But the equation for total potential energy being equal to -GMm/r makes it seem pretty absolute (in a non relativistic setting of course)..
Thank you for any help!
A bit confused from your wording, but you must keep in mind that with collisions and a moving frame of reference it might appear that energy is not conserved. For that reason, one does not usually use a moving frame unless it makes the calculations easier for what you need. But when having to use conservation of energy as a total, the whole frame must always be considered because there is no actual energy lost. Even if it is lost through friction the energy must be accounted for.
Potential energy between two bodies of mass is going to be relative to the mass of both objects. The force one feels on the other will be the same, so I am unsure on what you mean by absolute? The constant between two bodies is going to always be G with all other variables being able to be changed given different circumstances. (although usually mass is thought of as constant)
Also in the situation you gave, the energy gained may not be significant compared to that of the Earth but is going to be the same from the small ball. Why would they be different?
Your intuitition is telling you that the Earth won't gain any significant energy. Your reasoning is telling you that this doesn't make sense.
Why don't you test your intuition? How much kinetic energy does the Earth gain? How much kinetic energy does the ball lose? Do the calculated results match your intuition?
Likes RaulTheUCSCSlug and gmax137
FAQ: Conservation of energy in a moving frame
1. What is conservation of energy in a moving frame?
Conservation of energy in a moving frame is a fundamental principle of physics that states that the total energy of a system does not change over time, even when the system is moving.
2. How does the concept of conservation of energy apply to a moving frame?
In a moving frame, the total energy of a system is the sum of its kinetic energy (energy of motion) and its potential energy (energy due to position). Conservation of energy means that the total energy of the system remains constant, even as the system moves and its individual energy components may change.
3. Can energy be created or destroyed in a moving frame?
No, according to the law of conservation of energy, energy cannot be created or destroyed in a moving frame. It can only be transferred or transformed from one form to another.
4. What factors can affect the conservation of energy in a moving frame?
The conservation of energy in a moving frame can be affected by external forces such as friction, air resistance, and gravity. These forces can change the amount of kinetic and potential energy in a system, but the total energy will still remain constant.
5. How is the conservation of energy in a moving frame relevant in real-world applications?
The concept of conservation of energy in a moving frame is essential in understanding and predicting the behavior of various physical systems, such as machines, vehicles, and celestial objects. It is also crucial in designing efficient and sustainable technologies, such as renewable energy sources.
