Conservation of Energy in Trampoline Bounce
In summary, the conversation discusses a problem where a person falls onto a trampoline and experiences an upward force, leading to an increase in kinetic energy. The question is raised about how energy is conserved in this situation, and it is suggested that the trampoline may be doing non-conservative work. However, it is noted that the force provided by the trampoline is the impulse and is relevant to the situation. The conversation ends with a clarification that the OP's concern about energy conservation is valid and they were thinking about it correctly.
ManfredArcane
A person with a mass of 50kg falls onto a trampoline with a downward speed of 4.89 m/s. Due to the trampoline, the person experiences a net upward force of 887 N for a time of 0.578 s.
The person leaves the trampoline with a speed of ___ in the upward direction.
P0+J=Pf
KE0+PE0+Wnc=KEf+PEf
I was able to calculate the correct answer (given by a solution sheet), V=5.364 m/s, using the momentum impulse equation, P0+J=Pf. If this value is correct, however, I don't understand how energy is being conserved. The speed increases after the person bounces off the trampoline while the mass remains constant. Thus there is a net increase in kinetic energy. The only answer that I can think of is that the problem statement treated the trampoline as applying a force to the person that was not commensurate with the action of a spring, in other words, as doing non-conservative work. I just want to make sure I am not missing something here conceptually. Thanks, and sorry if I made any mistakes with this post.
ManfredArcane said:
the person experiences a net upward force of 887 N*m
That is not a force. The units are wrong.
My mistake, the unit given in the problem was Newtons.
Presumably the person also expended energy in jumping off the trampoline. Like people do when they, you know, jump on trampolines to get higher and higher.
Likes russ_watters, PeroK and berkeman
ManfredArcane said:
Homework Statement:: A person with a mass of 50kg falls onto a trampoline with a downward speed of 4.89 m/s. Due to the trampoline, the person experiences a net upward force of 887 N for a time of 0.578 s.
Relevant Equations:: P0+J=Pf
KE0+PE0+Wnc=KEf+PEf
Firstly, the problem states the person falls on a trampoline. Secondly, Due to the trampoline, the person experiences a net upward force of 887 N for a time of 0.578 s.
Given this problem statement, you are completely justified in your concern. This shows that you are a critical reader, and thinking more deeply and accurately than you were given credit for ( don't let the snide remark get under your skin).
Good catch!
Which is typically what happens when you are in the air above a trampoline.
Which is also perfectly valid for someone jumping on a trampoline. Even when jumping, the force providing the impulse is that on the person due to the trampoline. If you jump off the ground, the force that provides the impulse on you as a system is that from the ground acting on you, even if that force is doing no work.
erobz said:
Don't let the snide remarks get under your skin.
There was nothing snide intended about the remark. Your interpretation in making it so and making a snide comment of your own is however noted.
It is perfectly valid to ask questions to get clarification when something does not match up in your head. It is another to make snide remarks about perfectly valid resolutions.
Likes russ_watters, berkeman and hutchphd
The energy input is not due to the trampoline.
That is irrelevant. The force is and it is the force that is given and supplies the impulse.
Likes hutchphd
Are seriously trying to claim that your remark here is not belittling?
The OP was asking how energy was not conserved, and whether or not he was thinking about it correctly. And they were perfectly correct.
Yes. But you may read into it what you will. It is the internet and people will read things differently than they are intended.
You are however changing the subject.
The OP is perfectly entitled and correct to ask for clarification because indeed kinetic energy is higher after contact. It is however the case that the situation I described is well within the constraints of the problem formulation and also describes a situation where the kinetic energy after trampoline contact would indeed be increased due to the release of chemical energy in the person’s legs. Making snide remarks about however I formulated myself does not change this.
Likes russ_watters and erobz
How does anyone ever emerge from an armchair if their kinetic energy is conserved?
In the context of an idealization of a mass falling on to a spring (which the OP's problem obviously is), an increase in kinetic energy is absolutely suspicious.
  • Skeptical
Likes hutchphd
Seriously though, this issue is something many people wonder about when starting physics: How you can jump off the ground when the force from the ground on you does no work. The resolution being that the energy is added elsewhere (by expending chemical energy stored in the muscles), but the impulse comes from the ground. Looking at the full flow of energy and momentum is quite beyond introductory mechanics though.
(My emphasis) I disagree. This is your interpretation but there is nothing in the problem as stated that actually tells you this. You are given a falling speed before the person hits the trampoline and a force. The typical idealized elastic mass on spring problem would have been unlikely to give you the force (although it might ask you to compute the force at some point of the peocess).
Likes russ_watters
An inert mass cannot get up out of an armchair, but a person can. That's the point, surely?
Just as an aside, while I do believe it is the clear intent of the problem author to highlight a jump with resulting higher speed, he/she should be more careful with the use of significant digits … considering the mass of the person has one or possibly two significant digits at best, having an answer and other input with four seems excessive.
I see this problem as an inelastic explosion between trampoline and the person. The extra energy of the explosion comes from biochemical energy stored in the person's muscles. I see nothing wrong modeling it like this.
Likes russ_watters
No...none of this group attack is actually the point. The point was to confirm to the OP that his interpretation of a person as an idealized mass falling on an idealized spring somehow gaining kinetic energy was indeed suspicious without being cheeky about it. Are you seriously teachers. I pity your students...
I was a PE teacher but none of my students could do anything because of what they learned from a dodgy physics teacher. "We can't run or jump, sir" they used to say "because of energy conservation!"
See...Understanding what to expect of an assumed model is an important developmental objective.
Thread is closed. I think we all saw the problem with the initial statement of the problem, and tried to help the OP understand what may have been going on instead.
@erobz -- check your PMs.
Likes Orodruin, russ_watters, jbriggs444 and 1 other person
FAQ: Conservation of Energy in Trampoline Bounce
How does the conservation of energy apply to trampoline bounce?
The conservation of energy states that energy cannot be created or destroyed, only transferred from one form to another. In the case of trampoline bounce, the energy from the initial jump is converted into kinetic energy as the person bounces up and down.
What factors affect the conservation of energy in trampoline bounce?
The height and weight of the person jumping, the elasticity of the trampoline, and the force of the initial jump all affect the conservation of energy in trampoline bounce. A heavier person or a less elastic trampoline will require more energy to achieve the same height as a lighter person or a more elastic trampoline.
How does gravity play a role in the conservation of energy in trampoline bounce?
Gravity is a force that pulls objects towards the Earth's center. In trampoline bounce, gravity acts as a downward force, causing the person to come back down to the trampoline after each bounce. This force also helps to transfer the person's potential energy into kinetic energy.
Can the conservation of energy be observed in trampoline bounce?
Yes, the conservation of energy can be observed in trampoline bounce. If you measure the height of a person's bounces, you will notice that they gradually decrease with each bounce. This is because the energy is being transferred into other forms, such as heat and sound, and is not being conserved.
How does the conservation of energy in trampoline bounce compare to other forms of energy conservation?
The conservation of energy in trampoline bounce follows the same principles as other forms of energy conservation. Energy cannot be created or destroyed, only transferred. This concept applies to all forms of energy, including mechanical, thermal, and electromagnetic energy.
