Dousin12
- 44
I get that less percentage energy is conserved from potential to kinetic energy by measuring h and v with two balls for the heavier ball. I am trying to sort of why actually is like that!
Two balls where dropped down from a ramp with different masses and volume. The smaller sphere has a smaller mass, and less volume ofc. Velocity was measured in the end of the ramp!
It was not rolling 100% perfect so i think that friction will come into account a bit. Since the normal force is bigger for the heavier ball, and friction is reliant on normal force the heavier ball will feel friction easier. The two speheres weren't made of the material, maybe the heavier ball was made of a material with bigger friction constant, mu. The heavier ball have bigger area so it would feel air resistance more!
Questionmarks:
1. Will rolling friction come into play when a sphere is rolling down a ramp and gaining more kinetic energy?
2. How can i physically describe that the bigger ball will feel bigger air resistance? (I made an attempt, but can't really explain)
3. I know that potential energy will transform into to kinetic energy and rotational kinetic energy, however with different h, should less energy be turned into kinetic energy percentagewise, or shouldn't be the same for every h, since everything will just increase, the velocity will increase, so more kinetic energy, it will roll around more times so more rotational kinetic energy, longer distance that friction can make a work, so more friction energy etc.. Should these be propotional to eacother because i weirdly enough got that the trend that the higher h , especially for the heavier ball the more kinetic energy is conserved, higher percentage compared to the starting potential energy. Is it just an accident or is there any way to explain that?
4. Any general idea why the heavier ball conserve less kinetic energy in percentage!
Thanks in advance! :)
