Conservation of Energy - Max height WITH Air resistance
In summary, for a ball (m=0.7kg) dropped from a height (h=30m) with air resistance force given by F=kv^2, the maximum height reached after a perfectly elastic collision can be calculated by setting up a differential equation using the law of conservation of energy and the work done by the air resistance force. Attempting to account for energy loss using the formula for work does not yield accurate results due to overestimating the loss. A more accurate approach is to start with forces and obtain a differential equation.
kornelijepetak
A ball [itex](m=0.7kg)[/itex] is dropped from a height [itex](h=30m)[/itex]. The air resistance force is given by the formula [itex]F=kv^2[/itex] where [itex]k=0.0228[/itex] and [itex]v[/itex] is the ball's speed. The ball bounces after a perfectly elastic collision.
  • Calculate the maximum height the ball reaches after the collision!
Since we are talking about a perfectly elastic collision, the kinetic energy before and after the collision is the same.
[itex]E_k = E_k'[/itex].
Also the law of conservation of energy holds.
I am not sure what I'm doing wrong. Here's what I tried:
  • DURING FALL
First I tried to write the energy state during the fall. Left side of the equation is the state at [itex]t=0[/itex], and the right side is at the moment just before the collision.
[tex] E_k + E_p + W = E_{k}' + E_{p}'[/tex]
[itex]W[/itex] is the work that the air resistance force does on the ball.
Kinetic energy at start equals 0, and potential energy at the moment of collision equals 0.
That leads to (*):
[tex] E_p + W = E_{k}'[/tex]
The speed of the rigid body during the free fall is given by [itex]v^2=2gh[/itex], which leads to [tex]F(v)=kv^2 \Rightarrow F(s)=2kgs[/tex]
The work of the air resistance along the fall
[tex]W=\int F(s) \, ds=\int 2kgs\, ds=2kg\int s\,ds=2kg\frac{s^2}{2}=kgs^2[/tex]
I repeat one of the previous equations (*), expanded:
[tex]mgh - kgh^2 = \frac{mv^2}{2}[/tex]
Here is the thing I am not sure about: should the Work be negative (like I have written) since the direction of the force that does the work is opposite of the movement?
Entering the given values in this equation I get [itex]v_{collision}=3.668 [m/s][/itex].
  • DURING RISE
Then I tried to write the energy state after collision and during the rise. Left side of the equation is the state at the moment just after the collision and the right side is the moment in which the height is at maximum [itex](y_{max})[/itex] (after the collision).
[itex]W[/itex] is the work that the air resistance force does on the ball during its rise.
Potential energy at the moment of collision equals 0, and kinetic energy at the highest point equals 0.
That leads to (**):
[tex] E_k + W = E_{p}'[/tex]
I used the previously calculated formula for work, only this time, the height is not [itex]h[/itex], but [itex]y_{max}[/itex].
Now I have:
[tex]\frac{mv^2}{2} - kgy_{max}^2 = mgy_{max}[/tex]
This gives me a quadratic equation for [itex]y_{max}[/itex].
The roots of this quadratic equation are ([itex]v[/itex] entered as [itex]v_{collision}[/itex]):
[itex]y_{max1} = 0.671[m],y_{max2}=-31.372[m][/itex].
The latter has no sense for height, and the former is incorrect. The correct answer is [itex]9.15[m][/itex].
What do I do incorrectly?
Any hints?
Hello KP, welcome to PF :smile: !
v^2=2gh## gets spoilt by the loss of kinetic energy due to air resistance, so you'll have to revert to a differential equation. Would that work for you ?
It probably would, but I am not sure what you mean. You mean diff equation for [itex]v[/itex]? Unfortunatelly, I am not sure I know what I need to do.
Yes, I mean ##F = ma## which is indeed a differential equation for ##v##. Fill in ##ma = m{dv\over dt}## and the two forces acting on ##m##.
kornelijepetak said:
The speed of the rigid body during the free fall is given by ##v^2=2gh##, which leads to
##F(v)=kv^2 \Rightarrow F(s)=2kgs##
##W=\int F(s) \, ds=\int 2kgs\, ds=2kg\int s\,ds=2kg\frac{s^2}{2}=kgs^2##​
This is a valiant attempt to account for energy loss due to air resistance, but it doesn't work.
You start by computing the speed it would have after a fall of a certain distance with no resistance, then find the drag at that point. But it's too late, since it would not have reached that speed. As a result, you overestimate the loss.
As BvU says, you need to start with forces and obtain a differential equation.
FAQ: Conservation of Energy - Max height WITH Air resistance
1. How does air resistance affect the conservation of energy for an object at maximum height?
Air resistance, also known as drag, is a force that opposes the motion of an object through the air. In the case of an object at maximum height, air resistance will affect the conservation of energy by reducing the object's potential energy. This is because some of the object's initial kinetic energy is converted into thermal energy due to the work done by air resistance.
2. Can an object reach its maximum height without any air resistance?
No, an object cannot reach its maximum height without any air resistance. This is because air resistance is always present and will always act on the object, causing it to lose some of its initial kinetic energy and not reach its maximum height.
3. How does the shape of an object affect the conservation of energy at maximum height in the presence of air resistance?
The shape of an object can greatly affect the conservation of energy at maximum height in the presence of air resistance. A streamlined object, such as a rocket or an airplane, will experience less air resistance and therefore conserve more of its initial kinetic energy compared to a less streamlined object, such as a cube or a sphere.
4. Is the conservation of energy still valid in the presence of air resistance?
Yes, the conservation of energy is still valid in the presence of air resistance. While some of the object's initial kinetic energy is converted into thermal energy due to the work done by air resistance, the total energy of the system (object + air) remains constant. This means that the law of conservation of energy still holds true.
5. How does the speed of an object affect the conservation of energy at maximum height in the presence of air resistance?
The speed of an object plays a crucial role in the conservation of energy at maximum height in the presence of air resistance. The faster the object is moving, the more air resistance it will experience, and therefore the more kinetic energy will be converted into thermal energy. This means that a slower object will conserve more of its initial kinetic energy and reach a higher maximum height compared to a faster object.
