Conservation of Energy of a thrown stone
In summary: Pythagoras.In summary, the stone's initial speed can be calculated using the conservation of energy equation at the initial position and the maximum height above the release point. This involves taking into account both the vertical and horizontal components of the velocity, which are related by the launch angle of 53°. The vertical component can be found using the stone's maximum height, and the horizontal component can be found using the Pythagorean theorem.
knowNothing23
35
A stone is thrown upward at an angle of 53° above the horizontal. Its
maximum height above the release point is 24 m. What was the stone’s initial
speed? Assume any effects of air resistance are negligible.
Emech=0
On my book's solution, I do not understand, why the V(y) component of the velocity is not taken into account. Also, the solution is not given in polar form, but the V(x) component was used at Hmax.
My solution used the Y component of the velocity at Hmax and is 85m/s. I used conservation of Emech at initial position and Hmax.
Thank you.
Can you elaborate on your solution? We can't comment on what we can't see :smile:
Ok, V(y) is 0 m/s at max height.
So, in the Y direction, you have the following
U (initial velocity) = X
V (Final velocity) = 0
A (acceleration) = -9.8 m/s/s
S (displacement) = 24
T (time) = t
Using the appropriate equation of motion ( V^2 = U^2 + 2as) you can then find the Y comonpen of initial velocity. BUT YOU'RE ASKED FOR SPEED.
Remember Speed is a scaler quantity and is typical the magnitude of the vector.
Please say if you need help finding total time etc..
DarthFrodo: I need to use Conservation of energy equations.
Gneill: I thought that I made a straight forward and known mistake.
My procedure is:
Position 1 is the ground level. Position 2 is at Hmax.
Using position 2 and 1 for conservation on energy:
K2-K1+ U2-U1=0, where K and U are kinetic and gravitational potential energy respectively. Also, there is no air drag or other forces interfering.
K2 is zero, for I used the V(y) component. This is one aspect of the solution that differs from the book's solution.
So,
-(1/2)(Vsin(angle))^(2) +mg(Hmax)=0 , V is initial velocity.
48g/ (sin(angle))^(2) =(V)^(2)
(1/sin53)( (48)(9.81) )^(1/2)=V
85.1022= V.
K2 ≠ 0 . The horizontal component of velocity is NOT zero. (V1)x = (V2)x = Vinitial cos(θ)
(1/2)mV2 = (1/2)m(Vx2 + Vy2)
My procedure is:
So,
85.1022= V.
You have a problem with your final value. The second to last line looks okay, but the numerical result that you calculate from it is not! Perhaps you can detail the intermediate values in the calculation?
On my first post:
3. The Attempt at a Solution
On my book's solution, I do not understand, why the V(y), vertical component of the velocity, is not taken into account.
Now, I understand the procedure. I did not realize that both components, where taken into account, but not all were written.
Thank you, SammyS.
You're working with the vertical component of the velocity when you write V*sin(53°), where V is the initial speed. You're applying conservation of energy to find this initial vertical component, V*sin(53°), which is fine.
A side question here:
What does the knowNothing23 mean by "Emech=0"?
Emech=0
Thank you.
Perhaps you have written it in an unusual way, but the vertical component [y-component] is zero at maximum height; otherwise it will be still getting higher?
The angle - 53° - gives you the relationship between vertical and horizontal components at launch. [That angle is very familiar to regular problem solvers].
The maximum height reached enables you to calculate the vertical component. Once you have the vertical and horizontal components of V you can get the actual V
FAQ: Conservation of Energy of a thrown stone
What is the Conservation of Energy of a thrown stone?
The Conservation of Energy of a thrown stone refers to the principle that energy cannot be created or destroyed, but can only be transformed from one form to another. In the case of a thrown stone, the potential energy stored in the stone is converted into kinetic energy as it moves through the air.
Why is the Conservation of Energy important when discussing a thrown stone?
The Conservation of Energy is important when discussing a thrown stone because it helps us understand and predict the motion of the stone. By knowing that energy is conserved, we can calculate the stone's velocity, height, and other factors that affect its trajectory.
How does the height and velocity of a thrown stone affect its Conservation of Energy?
The height and velocity of a thrown stone directly affect its Conservation of Energy. As the stone is thrown higher, it gains potential energy and loses kinetic energy. As it falls back to the ground, it converts this potential energy back into kinetic energy. The velocity of the stone also affects the amount of kinetic energy it has and how far it will travel before losing all its energy.
Are there any factors that can affect the Conservation of Energy of a thrown stone?
Yes, there are several factors that can affect the Conservation of Energy of a thrown stone. These include air resistance, the angle at which the stone is thrown, and the surface it lands on. These factors can influence the stone's velocity and height, and therefore affect its energy conservation.
How is the Conservation of Energy of a thrown stone related to other principles of physics?
The Conservation of Energy of a thrown stone is related to several other principles of physics, such as the Law of Inertia and Newton's Laws of Motion. These laws help us understand how the stone will move based on its energy conservation and other external factors. The Conservation of Energy also has implications for other areas of physics, such as work, power, and momentum.
