Conservation of Energy, PE & KE, block on incline with KE & friction?
In summary, the 4 kg bundle starts up a 30° incline with 128 J of kinetic energy. If the coefficient of friction is 0.30, it will slide up the plane 4.29m.
nchin
172
A 4 kg bundle starts up a 30° incline with 128 J of kinetic energy. How far will it slide up the plane if the coefficient of friction is 0.30?
So the solution to the problem is 128 = 4(9.8)(x)(sin30) + 0.30 (4)(9.8)(x)(cos30)...x = 4.29m
I don't understand the solution.
so 128 = 4(9.8)(x)(sin30) + 0.30 (4)(9.8)(x)(cos30) is
KE = mgh (sin theta) + Friction (mgh)(cos theta)
I thought it would be KE = PE + Friction, why is mgh added twice?
KE=PE-W where W is work done by friction.
KE=mgh-Friction*distance
Friction=normal force*coefficient of friction, now normal force is mgh*cos30
The coefficient of friction is just a unitless factor that tells you how much the (maximum) force of friction compared to the normal force. What is the normal force?
It really is KE = PE + Losses to friction
have a closer look at the connection between the height above the starting point and how far along the slope the block travels
Isn't friction just
Coefficient x mg
Without height?
For friction, F=μFn. Fn isn't mg. Second, x isn't h. It's the distance the block slides along the surface. x sin(theta) is h. Third, x cos(theta) is also not h.
What you are calculating is not the force, but the work, which is force times distance. The force has an mg term in it, but the work has an mgh term.
nchin said:
Isn't friction just
Coefficient x mg
Without height?
Yes, it was a typo.
By the way you have a little typo too. Fμ=μFn, now in y-direction ƩF=0⇔Gy=Fn →Fn=mg*cos30 So Fμ=μ*mg*cos30 Do you agree with me now?
Ok that makes sense but why is the solution to the problem is:
Which is
Shouldn't it just be
KE = (mgh) sin theta + coefficient of friction(mg) (cos theta)?
But that gives the wrong answer
But it would make more sense because friction = mu x mg
Were you talking about the part that looks like Fn*Fn? That's not a typo, it's two separate sentences.
I am sorry, it really seemed to me Fn*Fn
nchin said:
[KE] = (mgh) sin theta + coefficient of friction(mg) (cos theta)
Look at the units.
[KE]=J=kg*m2/s2
[m]=kg
[g]=m/s2
[h]=m
[sin(θ)]=unitless
[mgh sin(θ)]=kg*m2/s2
[μ]=unitless
[m]=kg
[g]=m/s/s
[cos(θ)]=unitless
[μmg cos(θ)]= kg*m/s2
Without going into any physics, your answer is wrong because the units don't agree.
Let's start from the top.
  1. What are the FORCES acting on the bundle? Write these in terms of their components parallel and perpendicular with the slope.
  2. What is the net force? It should be parallel to and down the slope.
  3. Use [itex]W=\int\vec{F}\cdot d\vec{x}[/itex] to calculate the WORKas a function of the distance the bundle travels. Remember, [itex]d\vec{x}[/itex] is in the direction parallel to and up the slope, so your answer should be negative.
  4. Solve KE+W=0 for x, the distance up the slope. This is NOT the distance in the horizontal direction, nor is it the height.
Related to Conservation of Energy, PE & KE, block on incline with KE & friction?
1. What is the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, it can only be transformed from one form to another. This means that the total amount of energy in a closed system remains constant.
2. How does potential energy (PE) and kinetic energy (KE) relate to each other?
Potential energy is the energy an object possesses due to its position or state, while kinetic energy is the energy an object possesses due to its motion. The two are related in that potential energy can be converted into kinetic energy and vice versa.
3. How does a block on an incline demonstrate the concept of PE and KE?
When a block is placed on an incline, it has potential energy due to its position above the ground. As the block slides down the incline, its potential energy decreases while its kinetic energy increases. At the bottom of the incline, all of the potential energy has been converted into kinetic energy.
4. How does friction affect the block's KE on an incline?
Friction is a force that opposes motion, so it will act in the opposite direction of the block's motion down the incline. This means that friction will decrease the block's kinetic energy by converting it into thermal energy. As a result, the block will have less kinetic energy at the bottom of the incline compared to if there was no friction.
5. How does the conservation of energy apply to a block on an incline with KE and friction?
According to the law of conservation of energy, the total amount of energy in a closed system remains constant. In the case of a block on an incline with KE and friction, the initial potential energy of the block is converted into both kinetic energy and thermal energy. The total amount of energy (PE + KE + thermal energy) remains the same throughout the block's motion, demonstrating the conservation of energy.
