AVD
- 8
Conservation of Energy - "Swing Problem"
Hi everyone I'm having some trouble solving this problem because I'm not sure what method to use. It seems like it could involve Centripetal acceleration, conservation of energy, and/or conservation of momentum.
Problem
A swing seat of mass M is connected to a fixed point P by a massless cord of length L. A child also of mass M sits on the seat and begins to swing with zero velocity at a position at which the cord makes a 60° angle with the vertical is shown in Figure I. The swing continues down until the cord is exactly vertical at which time the child jumps off in a horizontal direction. The swing continues in the same direction until its cord makes a 45° angle with the vertical as shown in Figure II: at that point it begins to swing in the reverse direction. With what velocity relative to the ground did the child leave the swing? (cos 45° = sin 45° = , sin 30° = cos 60° = 1/2, cos 30° = sin 60° = /2)
Diagram
http://img222.imageshack.us/img222/4968/phys1rp6.jpg
So far, I figured you could use the conservation of energy formula
Pe1+Ke1=Pe2+Ke2 to determine velocity in terms of L
Ke1 cancels out when the swing is at rest and Pe2 cancels out when the swing is vertical.
mgh = 1/2mv^2
( I wasn't sure if Pe2 should include the mass of the second person or not)
This is assuming the person jumped off
(2m * 9.8m/s^2 * L-Lcos60) = (1/2 * m * v^2)
18.6L m/s = v^2
This is if the person is still on the swing
(2m * 9.8m/s^2 * L-Lcos60) = (1/2 * 2m * v^2)
9.8L m/s = v^2
I tried a few things from here - using centripetal acceleration and angular momentum formulas but nothing worked out. I'm not sure if I'm even starting it right.
Thanks for any help & I'm still a high school student so I may not understand some terminology or if I'm even doing the math right (sorry for that)
Problem
Diagram
mgh = 1/2mv^2
18.6L m/s = v^2
9.8L m/s = v^2
