Ronnie1303
- 2
1. A bullet (m1 = 0,01 kg) hits a ball hanging on a thread (m2 = 1kg) and stays in he ball (therefore new system = m1 + m2) and pushes the whole system into the height of 0,2m (max potential energy, Kinetic energy = 0) Calculate the speed initial speed of bullet (v) and the initial speed of whole system (v').
2. Law of Conservation of Energy: Ek + Ep = const.
Law of Conservation of momentum: p1 + p2 = const.
3. So I've been doing the calculations with 2 different approaches and each gives a different result and I don't know why, so here they are:
Approach #1: Let the whole system be an isolated system. Therefore the kinetic energy of bullet should equal the potential energy of the whole bullet+ball system at the max Ep state. Therefore:
1/2 m1 v(bullet)^2 = (m1 + m2)gh
(Note that for symplification we consider g = 10m/s^2). So I get
v = sqrt{[2(m1+m2)gh]/m1}
which gives the speed of bullet approximately 20,1 m/s. Now for calculation the speed of the system (at Ep of system = 0 and Ek is max) I used similar approach (Ek1 = Ek2) and got v' = 2m/s . Energy is equal at all times.
However here comes the second approach:
Conservation of momentum says that: m1v1 = (m1+m2)v' so let's use the law of conservation of energy once more, however let's start with the initial kinetic energy of system (ball + bullet) should equal the potential energy at it's max state. Therefore:
1/2(m1+m2)v'^2 = (m1+m2)gh
which gives the same result of speed of the system as v' = 2m/s.
However now I use this speed in the law of conservation of momentum and get:
v(bullet) = ([m1+m2]v')/m1 which gives the speed of bullet as 202 m/s.
So here's the conflict: Working with the conservation of energy purely the speed of bullet is aproximately 20,1 m/s. Working with the conservation of momentum the speed is 202 m/s + when I start calculating the energy values, it differs! So I don't know which solution is correct and why. Thanks for help in advance!
