I Conservation of finite difference for vibration equations
feynman1
Let's discuss whether the energy under a finite difference (FD) scheme is conserved. Take the simplest vibration eq mx''+kx=0, which one will use a FD scheme to solve. The energy is mx'^2/2+kx^2/2. Whether the energy is conserved doesn't depend on the FD scheme for the ODE but upon the FD scheme for the x' term in the energy?
THe example you have given is an ODE with two dimensions: <br /> \begin{align*}<br /> x&#039; &amp;= v \\ v&#039; &amp;= - x \end{align*} where time is scaled to that k/m = 1. Then the energy is E = \frac{12}(v^2 + x^2).
The result of your numeric integration is a sequence (x_n,v_n) which approximates the solution at time (t_n. But there will be errors, so x_{n+1} = x(t_{n+1}) + \epsilon_x(n) and similarly for v. Hence <br /> \begin{align*}<br /> E_{n} &amp;= \frac12 \left( (v(t_n) + \epsilon_v)^2 + (x(t_n) + \epsilon_x)^2 \right) \\<br /> &amp;= E(t_n) + v(t_n) \epsilon_v + x(t_n)\epsilon_x + \frac12 (\epsilon_v^2 + \epsilon_x^2).<br /> \end{align*}<br /> so assuming (x_n,v_n) is exact, at time t_{n+1} you will see that the energy has changed by an amount \Delta E = v(t_{n+1}) \epsilon_v(n+1) + x(t_{n+1})\epsilon_x(n+1) + \frac12 (\epsilon_v^2(n+1) + \epsilon_x^2(n+1))<br /> which in general is not zero.
So for a PDE the answer must be that whether or not energy is conserved depends on both the time integration and the spatial discretization.
Thank you very much for the analysis. I actually meant the same, that is I didn't mean to say that the FD scheme for the ODE doesn't affect but rather meant that the x' term in the energy would even if the FD scheme for the ODE gave an exact solution.
Your analysis is beautiful. Can we conclude that a FD scheme is either dissipative (positive/negative) or dispersive (positive/negative)? Is there any conservative FD scheme for this simplest vibration equation?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
