Conservation of four-momentum concepts, frames
In summary, conservation of four-momentum is a fundamental principle in physics that states the total four-momentum of a closed system remains constant. It is significant because it allows us to make predictions and understand the behavior of particles and systems. It also relates to the concept of frames of reference, as it holds true in all inertial frames. It cannot be violated and has practical applications in various fields, including particle physics, astrophysics, and engineering.
binbagsss
1,305
I've read that they must be calculated in the same frame , and so to calculate them in the easiest frame.. *
So for a collision when I compute the momentum before and after I should do this in the easiest frame.
Considering a specific collision where we are computing the minimum energy to create some given particles after a collision that occurs between a particle with energy E, colliding into a stationary particle, both particles have mass m.
Questions:
1) Isn't the chose of frame fixed by the requirement of minimum energy and so we need a frame in which the created particles are at rest - is there only one such frame?
2) In evaluating the four-momentum before the collision, I get p =(E+mc,p,0,0).
(Assuming the collision to occur in 1-d x direction and using natural units.)
Where p is the momentum of the not stationary particle, and is unknown.
- Here I'm unsure how * applies and what frame we are evaluating in - we have to use a frame where the colliding particle has energy E as this is the only data known?
So by choosing a frame in which the final particles are at rest, are we able to evaluate the four-momentum in different frames before or after the collision? Or how would we know we have calculated four-momentum before and after in the same frame?
I think I might be confused with the space-time interval susu[/SUB ]which is the same in every frame.
Any help greatly appreciated, thank you !
There is only one frame where the created particles are at rest (apart from irrelevant things like translations and rotations), but you can consider physics in all frames. With 4-vectors, finding this frame first is more work than necessary. You have a direct way to get the center-of-mass energy.
You can do that.
By looking at what you calculated.
mfb said:
You can do that.
So momentum is frame invariant?
No. The vectors will be different in different frames. I just said you can calculate them.
In terms of applying momentum conservation then, you can only do it when the vectors are calculated in the same frame (before and after collision) ?
Questions:
You said the energy is a minimum when the created particles are at rest, but this can happen in only one frame. It can't happen in the lab frame because initially you have momentum ##p## in the x-direction. If everything was at rest afterward, momentum wouldn't be conserved. So to find the minimum energy, then, you want to analyze the situation in the frame where you can have all of the particles at rest after the collision, and then once you have the result of this analysis, you need to figure out what it will look like in the lab frame.
Yes, by using the appropriate Lorentz transformation.
I'm not sure what you mean here.
I think I might be confused with the space-time interval susu which is the same in every frame.
This is an instance of another tool you have at your disposal to relate quantities between different frames. If you have a four-vector ##p^\mu## in one frame and a corresponding four-vector ##q^\mu## in another frame (in other words, ##p^\mu## and ##q^\mu## are related by a Lorentz transformation), then the quantity ##p^\mu p_\mu## will be equal to ##q^\mu q_\mu##. The space-time interval is the particular case where the four-vector is (t, x, y, z).
FAQ: Conservation of four-momentum concepts, frames
1.
What is conservation of four-momentum?
Conservation of four-momentum is a fundamental principle in physics that states that the total four-momentum of a closed system remains constant, regardless of any internal interactions or external forces acting on the system.
2.
What is the significance of conservation of four-momentum?
The conservation of four-momentum is important because it allows us to make predictions and understand the behavior of particles and systems in terms of their energy, momentum, and mass. It also helps us understand the fundamental laws of nature, such as the laws of conservation of energy and momentum.
3.
How does conservation of four-momentum relate to the concept of frames of reference?
Conservation of four-momentum is closely related to the concept of frames of reference, as it describes how the total four-momentum of a system is the same in all frames of reference. This means that the laws of physics, including conservation of energy and momentum, hold true in all inertial frames of reference.
4.
Can conservation of four-momentum be violated?
No, conservation of four-momentum is a fundamental law of physics that has been confirmed by numerous experiments. While it may appear to be violated in certain situations, this is often due to incomplete or incorrect measurements, or the presence of external factors that were not accounted for.
5.
How is conservation of four-momentum used in practical applications?
Conservation of four-momentum has numerous practical applications in fields such as particle physics, astrophysics, and engineering. It is used to analyze and predict the behavior of particles in accelerators, understand the dynamics of celestial bodies, and design efficient propulsion systems, among other things.
9K
