Conservation of linear momentum elastic string
In summary, when two bodies of different masses connected by a light elastic string are released, their momentum will be the same. This is due to the conservation of momentum in the horizontal direction, which results in the velocities being dependent on the individual masses of the bodies.
Kurokari
36
Two bodies P and Q of different masses on a smooth table are connected by a light elastic string which is stretched. P and Q are then released.
Which of the following is of the same magnitude for both P and Q
Speed, Acceleration, Momentum, Distance moved.
Answer: Momentum
m1v1 + m2v2 = m1u1 + m2u2
Since both bodies are at rest first, so initial velocity for both are 0.
This makes m1v1 + m2v2 = 0, m1v1 = - m2v2
My concern is that, since the question stated that both the bodies P and Q have different masses, so this must mean that in the equation m1v1 = - m2v2, the velocity v1 and v2 is different. The question does not mention anything about the length of the string extension, so I assume that it's the same length for both bodies P and Q.
Ok here's the deal, does this mean that velocity is somehow influence by the mass, like a ratio thing seeing how the equation can be expressed in a ratio form only with a negative sign.
If so, does this apply in a general sense, or only towards this case which is conservation of momentum.
or am I thinking far far away and has gotten it all wrong? :D
The light elastic string applies forces to the bodies that must be equal and opposite (since the tension in a stretched string is everywhere the same). The resulting accelerations, and hence velocities, depend upon the individual masses of the bodies. F = MA. So, yes, you could say it's a 'ratio thing'.
Velocity is not related to mass. As the momentum is conserved in the horizontal direction, the velocities of the bodies are related to mass. This particular equation is only applicaple where momentum is conserved. In other cases, you'd have to work out the equation fully for the exact expression.
You've got it right though.
Related to Conservation of linear momentum elastic string
What is the conservation of linear momentum elastic string?
The conservation of linear momentum elastic string is a fundamental principle in physics that states that the total momentum of a system remains constant if there are no external forces acting on it. In the case of an elastic string, this means that the total momentum of the string and any objects attached to it will remain the same as long as there are no external forces, such as friction or air resistance, acting on the system.
How does the conservation of linear momentum apply to elastic strings?
The conservation of linear momentum applies to elastic strings in the same way it applies to any other system. The total momentum of the string and any attached objects will remain the same as long as there are no external forces acting on the system. This means that if the string is stretched or compressed, the total momentum of the system will remain the same.
What are some real-world applications of the conservation of linear momentum elastic string?
The conservation of linear momentum elastic string has many real-world applications. One example is in sports, such as tennis or squash, where the player's racquet is connected to their arm by an elastic string. Another application is in bungee jumping, where the elastic cord attached to the jumper's body follows the principles of conservation of linear momentum.
What factors can affect the conservation of linear momentum in elastic strings?
The conservation of linear momentum in elastic strings can be affected by several factors. These include the elasticity of the string, the mass of the objects attached to the string, and the initial velocity of the objects. External forces, such as friction and air resistance, can also affect the conservation of linear momentum in elastic strings.
How is the conservation of linear momentum elastic string related to other laws and principles in physics?
The conservation of linear momentum elastic string is closely related to other laws and principles in physics, such as the conservation of energy and Newton's laws of motion. These laws and principles work together to explain the behavior of objects in motion, including the movement of elastic strings and the objects attached to them.
9K
