Conservation of Linear Momentum
In summary, the conversation discusses the concept of conservation of linear momentum in classical dynamics. The result is derived from the vector equation and applies to each component of linear momentum. The bolded part in the excerpt is confusing and the conversation attempts to clarify it, stating that the change in momentum in the direction perpendicular to the applied force is zero. They also discuss the role of a constant vector in this concept.
Bashyboy
1,421
In my Classical Dynamics book, I am reading about the topic alluded to in the title of this thread.
Here is an excerpt that is provided me with confusion:
"The total linear momentum [itex]\vec{p}[/itex] of a particle is conserve when the total force on it is zero
Note that this result is derived from the vector equation [itex]\vec{p} = \vec(0}[/itex], and therefore applies for each component of the linear momentum. To state the result in other terms, we let [itex]\vec{s}[/itex] be some constant vector such that [itex]\vec{F} \cdot \vec{s} = \vec{0}[/itex]indepent of time. Then [itex]\vec{p} \cdot {s} = \vec{F} \cdot \vec{s} = \vec{0}[/itex] or, integrating with respect to time [itex]\vec{p} \cdot \vec{s} = c[/itex] which states that the component of linear momentum in the direction in which in the force vanishes is constant in time
The part in bold is particularly confusing. Could someone help, please?
yeah, that is very weird. It looks almost like they are using ##\vec{s}## as an arbitrary vector. So in other words, imagine ##\vec{s}## is any arbitrary (but constant with time) vector, then ##\vec{F} \cdot \vec{s} = 0## Yeah, also, it should be 0 (a scalar) not a vector, since the dot product of two vectors is a scalar.
I think there is something in the definition of a linear vector space that says if the dot product of a vector ##\vec{F}## with any arbitrary vector in the vector space ##\vec{s}## is zero, then the vector ##\vec{F}## must be the zero vector. (In other words, it is just another way of saying that ##\vec{F}## is the zero vector).
What it is trying to say (not too well) is that the change in the component of momentum in the direction perpendicular to the applied force is zero.
You misread. Your book (apparently Marion & Thornton) says
"To state the result in other terms, we let ##\vec s## be some constant vector such that ##\vec F \cdot \vec s = 0## independent of time. Then ##\dot{\vec p} \cdot \vec s=\vec F \cdot \vec s = 0## or, integrating with respect to time ##\vec p \cdot \vec s = c## which states that the component of linear momentum in the direction in which in the force vanishes is constant in time."​
You missed the derivative of momentum, ##\dot{\vec p}##.
Ah, yeah. It could mean that. So if we choose a specific ##\vec{s}## for which ##\vec{F} \cdot \vec{s}=0## then this means for that specific vector ##\vec{s}##, we have: ##\vec{p} \cdot \vec{s} = c## (constant with time). So for example, if there are zero forces in the 'x' direction, then the momentum in the 'x' direction is constant.
FAQ: Conservation of Linear Momentum
What is the principle of Conservation of Linear Momentum?
The principle of Conservation of Linear Momentum states that in a closed system, the total linear momentum remains constant over time. This means that the total amount of momentum in a system before and after an interaction or event remains the same.
What is linear momentum?
Linear momentum is a measure of an object's motion in a straight line. It is equal to the product of an object's mass and velocity. In other words, the greater the mass or speed of an object, the higher its linear momentum.
What is an example of Conservation of Linear Momentum in everyday life?
A common example of Conservation of Linear Momentum is a game of pool. When the cue ball hits the other balls on the table, the total momentum of the cue ball is transferred to the other balls, causing them to move in different directions with the same total momentum as the cue ball had before the collision.
What is the relationship between force and momentum?
Force and momentum are directly proportional. This means that the greater the force applied on an object, the greater its change in momentum will be. This is described by Newton's Second Law: force equals mass times acceleration.
How does Conservation of Linear Momentum relate to Newton's Third Law of Motion?
Conservation of Linear Momentum is closely related to Newton's Third Law of Motion, which states that for every action, there is an equal and opposite reaction. When two objects interact, they exert equal and opposite forces on each other, resulting in a conservation of linear momentum in the system.
