Conservation of Linear momentum
In summary, the putty ball moves horizontally at 6m/s and collides with and sticks to a block that is lying on a frictionless horizontal surface. If 25% of the kinetic energy is lost, the mass of the block is 0.25m.
lisastar
A 500g putty ball moving horizontally at 6m/s collides with and sticks to a block lying on a friction-less horizontal surface. If 25% of the kinetic energy is lost, what is the mass of the block?
initial (i) = final (f)
m1v1+m2v2 = m1v1+m2v2
(m1v1i - m1v1f ) /v2f I'm confused :-( Somebody help me solve this. Also is the reduction of the kinetic energy relevant to solving this question?
Ummm, initial what = final what?
The sum of the initial momentum of the putty blob and the final momentum of the block is equal to the sum of the initial momentum of the putty blob and the final momentum of the block? That's not a principle of physics. That's just the reflexive law for equality: A quantity is always equal to itself.
It would be more helpful to equate the sum of the initial momentum of the blob plus the initial momentum of the block to the sum of the final momentum of the blob plus the final momentum of the block.
Can you write down that equality?
That's what I wrote up there P (initial) = P (final) sorry it wasn't clear.
By conservation of momentum
m₁ u = (m₁+ m₂) v
v/u = m₁ /(m₁+ m₂) EQN 1
Kinetic Energy -->
(1/2)(m₁+ m₂) v ² = (1/2) 0.25 m₁ u² EQN 2
Momentum must be conserved. Therefore we can say ##\vec p = m_{ball} \vec v_{ball}## must equal ##\vec p = m_{ball+block} \vec v_{ball+block}##. We also know that kinetic energy in this case is given by ## KE=\frac 1 2 mv^2##. With the given data we can calculate the initial kinetic energy which we can then easily use to calculate the final kinetic energy. Since we also know the momentum as well, we can then solve for mass and velocity of the block by putting one of them in terms of the other, and plugging into the other equation.
m₁ u = (m₁+ m₂) v
Kinetic Energy -->
This is getting a bit close to solving the problem for the student. Please start with hints, like "what do you know about the two final velocities?"
Likes sunnnystrong
Related to Conservation of Linear momentum
1. What is the law of conservation of linear momentum?
The law of conservation of linear momentum states that the total momentum of a closed system remains constant, regardless of any external forces acting on the system. In other words, the total amount of momentum before and after an interaction or event must be the same.
2. How is the conservation of linear momentum related to Newton's third law of motion?
Newton's third law of motion states that for every action, there is an equal and opposite reaction. This means that when two objects interact, their momentum changes in opposite directions, but the total momentum of the system remains the same.
3. What is an example of the conservation of linear momentum in action?
A classic example is a billiards game. When the cue ball hits another ball, the cue ball's momentum is transferred to the other ball, causing it to move. However, the total momentum of the system (the two balls) remains the same as it was before the collision.
4. How does the conservation of linear momentum apply to everyday life?
The conservation of linear momentum is present in many everyday situations, such as when a person jumps off a diving board or when a car collides with another car. It helps us understand and predict the outcomes of interactions between objects in motion.
5. What are the limitations of the law of conservation of linear momentum?
The law of conservation of linear momentum only applies to closed systems, meaning there are no external forces acting on the system. In reality, it is difficult to find a truly closed system, so this law is an idealization. Additionally, it does not take into account factors such as friction and air resistance, which can affect the momentum of objects in motion.
