Conservation of Linear Momentum
In summary: After the first collision you have, as you wrote, a mass 2m moving at speed v/2.The second collision is an elastic collision, so the conservation equations are:Δp=2μΔvwhere μ is the reduced mass of the colliding objects:$$μ=\frac{m_1m_2}{m_1+m_2}$$and Δv their relative velocity along the collision line.
Zulu2018
This question was on a recent AP Physics 1 exam as a multiple choice; "Three air track gliders, shown to the right all have the same mass M. Gliders 2 and 3 are initially at rest. Glider 1 is moving to the right with speed v. Glider 1 collides with glider 2 and sticks to it. This combination collides elastically with glider 3. Which of the following is most nearly the final speed of Glider 3?"
p = mv, p1 + p2 = p1' + p2'
initial p = mv, but inelastic results in 2mv/2, but second collision is elastic so 2m/v2 = (2mv)' + (1/3mv)', solve for the 1/3m's v'
This is most unclear. Please write out in more detail.
Is the 2m/v2 a typo for 2mv/2?
What is your final answer? Is the official answer known?
Apologies, yes it is a typo, should read 2mv/2. The final answer is .67v is what is given. Thank you!
I still don't know what that means or how you arrive at it.
That is the answer you got, or it is the official answer, or both? If both, what is your question?
I am requesting assistance as to what the correct answer is. Thank you for your help
No need for that, just be clear in what information you are giving.
So the 0.67v is the answer you got, is that true, yes or no?
Please write out in detail how you got your answer, explaining your steps. What you have posted so far is mysterious.
Yes. .67v is my answer.
pi = m1v1 inelastically collides with identical mass, now momentum shows velocity cut in half 2mv/2. This double-mass collides elastically with another identical mass, that must have a higher velocity than the double mass AFTER elastistic collision. Therefore the double mass velocity must decrease, while the last mass' velocity must increase. It made sense that the last mass would have 1/3 higher velocity and the double-mass would have just 1/3 velocity in order to conserve momentum.
"It made sense" is not a calculation. Please show the calculation.
Precisely why I am asking for help, Thank you in advance for any assistance.
Write out the two conservation equations for the second collision.
Please make it clear what each variable represents.
Momentum transfer - elastic collision: $$Δp=2μΔv$$
Related to Conservation of Linear Momentum
What is conservation of linear momentum?
The conservation of linear momentum is a fundamental law of physics that states that the total momentum of a closed system remains constant over time, unless acted upon by an external force. This means that the total amount of motion in a system will remain the same, even if individual objects within the system collide or interact.
How is linear momentum calculated?
The linear momentum of an object is calculated by multiplying its mass by its velocity. The formula for linear momentum is p = mv, where p is momentum, m is mass, and v is velocity.
What is an example of conservation of linear momentum in action?
One example of conservation of linear momentum is when a billiard ball collides with another billiard ball on a pool table. The first ball will transfer some of its momentum to the second ball, causing it to move. However, the total momentum of the two balls after the collision will be the same as the total momentum before the collision.
Is conservation of linear momentum always true?
Yes, conservation of linear momentum is a universal law and has been observed to hold true in all physical systems. However, in extreme situations such as at the quantum level or in the presence of strong gravitational fields, the law may need to be modified.
How does the conservation of linear momentum relate to Newton's laws of motion?
The conservation of linear momentum is a direct consequence of Newton's laws of motion, specifically the law of inertia and the law of action and reaction. These laws explain how an object will remain in motion unless acted upon by an external force, and how two objects will exert equal and opposite forces on each other when they interact.
