Conservation of Momentum and energy problem help
In summary, someone explain to me this because I am lost. They got two masses, one velecity. The equation is like mass times volocity + mass times velocity=0. However, they are having trouble understanding how to solve for the velocity. They tried multiplying and adding, but that doesn't seem to be the right answer. They also tried rearranging the equation, but that didn't help. They eventually figured out that potential energy is equal to kinetic energy and that the momentum equation is v=mgh.
kgbwolf
39
SOmeone explain to me this because I am lost. i got 2 masses one velecity. the equation is like is mass times volocity + mass times velocity=0
122kg*22m/s+14kg*v=0 I made these numbers up what i do is multiply and add then move my anwser to the other side becoming negative but that doesn't seem to be the right anwser.
ki even tried multipling then dividing by the remaining number still gives me the wrong anwser
Generally;
[tex]M_{1}V_{1} + M_{2}V_{2} = 0 [/tex]
Then Rearranging
[tex]V_{2} = - \frac{M_{1}V_{1}}{M_{2}}[/tex]
Ok i worked the first problem out now i have a nother problem
A 125kg pile driver falls from a hieght of 10m to hit a piling.
From this i see mass is 125kg and distance is 10m and it says find the speed it hits the piling? and the momentum how can i do this with just mass and distance or is distance really velocity?
Use conservation of energy. At 10m up the piledriver will have a potential energy of mgh. At the instant it hits the pile all the potential energy will be converted to kinetic [itex] \frac{1}{2}mv^2 [/itex]. You should be able to work out the velocity by rearranging and hence the momentum.
i did 1/2*m moved it to the other side negative and ttok the square root and 7.91m/s
and the right anwser is 14m/s
I got a different answer. What value did you get for the potential energy?
Yes, I got 14m/s.
12,250Newtons
how?...
Check you units. Newtons for energy? The value is correct. Now show me how you re-arrange the kinetic energy equation.
do u have msn IM??
No.....
1/2 times 125 = 62/1/2 and i took the square root gives me 7.9
[tex]E_{k} = \frac{1}{2} mv^2 \Rightarrow v = \sqrt{\frac{2E_{k}}{m}} [/tex]
Whats Ek...
kinetic energy
potential got it
The potential energy you calculated it would all be converted into kinetic energy. The same equation could be written
[tex]v = \sqrt{\frac{2mgh}{m}} \Rightarrow v = \sqrt{2gh}[/tex]
ok... got it
FAQ: Conservation of Momentum and energy problem help
1. What is the conservation of momentum and energy principle?
The conservation of momentum and energy principle is a fundamental law of physics that states that the total momentum and energy of a closed system remains constant over time, regardless of any internal changes or external forces acting on the system.
2. How does the conservation of momentum and energy apply to real-life situations?
The conservation of momentum and energy can be observed in various real-life situations, such as collisions between objects, pendulum swings, and even the movement of celestial bodies in space. It is a principle that applies to all physical systems, from the microscopic to the macroscopic level.
3. What is the difference between conservation of momentum and conservation of energy?
The conservation of momentum refers to the principle that the total momentum of a system remains constant, while the conservation of energy refers to the principle that the total energy of a system remains constant. Momentum is a vector quantity that takes into account an object's mass and velocity, while energy is a scalar quantity that represents the ability of a system to do work.
4. How do you solve conservation of momentum and energy problems?
To solve conservation of momentum and energy problems, you first need to identify the initial and final states of the system, and determine the total momentum and energy in each state. Then, apply the conservation principles to set up equations and solve for unknown quantities. It is important to carefully consider all the forces and energies involved in the system.
5. Can the conservation of momentum and energy principle be violated?
No, the conservation of momentum and energy principle is a fundamental law of physics that has been confirmed by numerous experiments and observations. In isolated systems, where no external forces act, the total momentum and energy will always remain constant. However, in open systems where external forces can influence the system, the conservation principles may not apply.
