Conservation of momentum and energy question
In summary, the gunpowder in the gun provides a forward force to the bullet and a backward force to the gun. The gun does not lose any energy in the process.
sameeralord
662
Hello everyone,
Let's say there was gun and a bullet with a mass of 1kg at rest. The bullet and guns speeds were 2 m/s in opposite directions after firing if I right the equations.
Kinetic energy
0.5m1v12 + 0.5m2v12 = 0.5m1v22 + 0.5m2v22 Why doesn't this equation work when objects are at rest. Mathematically I can understand but why physcially. Can anyone explain what is happening to kinetic energy in this scenario. Why does conservation of momentum equation hold in in inelastic collisions but not this one. I understand some energy is lost but why is it not affecting momentum.
Where does the energy to propel the bullet come from?
Ok let's say it came from gun powder. Then energy from gun powder would be given to the bullet, making it fly. Now the gun hasn't lost any energy or gained any but still it recoils. Why does it recoil?
The point is that mechanical energy is not conserved, so your equation doesn't apply. (But you can write an equation for conservation of momentum.) The explosion of the gun powder provides energy to both the bullet and the gun.
Thanks for the reply. Why does gun powder give a forward force to the bullet and backward force to the gun. Also why is this question not about gun powder and bullet. If gun powder provides the force, the reaction force should be towards gun powder, not the gun.
EDIT: Let me think this again. If force is rate of change of momentum. Since gun powder is part of the gun, the gun changed the momentum of the bullet. Oh so you can't change the momentum of something else without that momentum coming from you, meaning losing it. Oh so the gun retaliates. Oh so basically if you want to displace something, the person who is trying to displace the object is going to get displaced as well atleast a tiny bit. May be that is what momentum is saying. Is this r
Related to Conservation of momentum and energy question
What is conservation of momentum and energy?
Conservation of momentum and energy is a fundamental principle in physics that states that the total momentum and energy in a closed system will remain constant over time, regardless of any internal changes or interactions within the system.
How is conservation of momentum and energy related?
Conservation of momentum and energy are related because momentum and energy are both conserved in a closed system. This means that if the total momentum of a system changes, the total energy will also change in a corresponding way, and vice versa.
Why is conservation of momentum and energy important?
Conservation of momentum and energy is important because it allows scientists to make accurate predictions about the behavior of physical systems. It is also a fundamental law of nature that has been observed and confirmed through countless experiments.
What are some real-world examples of conservation of momentum and energy?
Some real-world examples of conservation of momentum and energy include collisions between objects, such as billiard balls on a pool table, and the motion of a pendulum. In both cases, the total momentum and energy of the system remains constant.
How is conservation of momentum and energy applied in engineering and technology?
Conservation of momentum and energy is applied in engineering and technology in a variety of ways, such as designing efficient energy systems and predicting the behavior of moving objects. It is also used in fields like aerospace engineering to design rockets and spacecraft that conserve momentum and energy during flight.
  • Mechanics
  • Mechanics
