Conservation of Momentum and Energy
The discussion focuses on the conservation of linear and angular momentum in a physics problem involving a block and clay. The key equations for momentum conservation are presented, indicating that the total momentum before and after the impact should be equal. The participant expresses uncertainty about whether their understanding of momentum conservation is correct, particularly regarding the potential energy change as the system moves. However, it is clarified that potential energy considerations are separate from momentum conservation. The conversation emphasizes the importance of distinguishing between momentum and energy in analyzing the system's dynamics.
ryankunzzz
Conservation of liner and angular momentum
H1=H2
r x M1V1= r x M2V2
G1=G2
M1V1=M2V2
I've gotten an equation for the velocity of the block and clay after the impact, and I also know that when the block reaches the highest point of its arc, its linear velocity is going to be the same as the velocity of the cart. Is the momentum going to be conserved and I can say MbV1=Vtot(M1+M2+M3)
It seems like that would be true. On the other hand, I'm thinking, "It seems too easy. Am I missing something?" But I can't think of what that might be.
Yes, and I believe that is where the hint is directed.
Likes TomHart
But what about the about the change in potential energy as the arm swings upward?
What about it? That's energy, not momentum.
  • · Replies 16 ·
  • · Replies 18 ·
