Conservation of Momentum and Mechanical Energy
A projectile with a mass of 20 g and an initial velocity of 100 m/s collides with a wooden block of 0.402 kg on a frictionless surface, leading to a maximum spring compression calculation. The conservation of momentum determines the combined velocity of the block and bullet system to be 4.95 m/s after the collision. Using the kinetic energy formula, the energy transferred to the spring is calculated, but initial attempts using force relationships were incorrect. The correct approach involves using energy relationships, particularly considering potential energy in the spring and work done against friction. The discussion highlights the importance of integrating friction into energy calculations for accurate results.
TG3
A projectile with a mass of 20 g has an initial horizontal velocity of 100 m/s when it hits and stops in a wood block of mass 0.402 kg. The block is sitting on a horizontal frictionless surface and is attached to a massless spring, initially relaxed, with spring constant 143 N/m. What is the maximum compression of the spring?
P= MV
K=1/2 MV^2
F=-kx
Initial Momentum of the Bullet = .02 x 100 = 2
Initial momentum of the Bullet/Wood system = 2 due to conservation of momentum.
2= .404 V
V= 4.95 m/s is the velocity of the block/bullet system.
K = 1/2 (.404) 4.95^2
K= 4.95 Due to conservation of Energy, this is also the amount of energy the spring exerts.
4.95 =143X
Wrong. I suspect the error in my calculation is near the end, but I don't know that for certain.
Thanks- once I used energy not force it was easy to find the distance. (.26 meters.)
In the second part though, there is friction (with a coefficient of friction of .25).
How do I deal with that using the energy relationship?
KE of block = PE gained by spring + work done against friction
  • · Replies 19 ·
