Conservation of Momentum: Change in mass
In summary: If you take the buggy as the system, the initial momentum will not be zero, as the man has a non-zero velocity with respect to the buggy. So the initial momentum will still be conserved in this system.In summary, two identical buggies with one man each are moving without friction along parallel rails. When the men exchange positions by jumping perpendicular to the motion, the first buggy stops and the second buggy's velocity becomes v. Using conservation of momentum, the initial velocities of the buggies are found to be v1 and v2. However, there is a mistake in the calculation as the velocity of the first buggy should remain constant in the frame of the buggy. The wording of the problem may also be ambiguous in terms of
Titan97
Two identical buggies 1 and 2 of mass ##M## with one man of mass ##m## in each, move without friction due to inertia towards along two parallel rails. When the buggies are opposite to each other, the men exchange positions by jumping in a direction perpendicular to motion of buggy. As a consequence, buggy 1 stops, while buggy 2's velocity becomes v. Find initial velocities ##v_1## nad ##v_2## of buggy 1 and 2.
Conservation of momentum
When the man jumps from buggy one, no force acts on the man+buggy system along horizontal. Since mass changes, velocity changes accordingly to make momentum constant. So,
##(m+M)v_1=Mu_1##
##u_1=(\frac{m}{M}+1)v_1##
This means velocity of buggy increased.
When the second man jumps to buggy one, again no force acts along horizontal. Hence,
##Mu_1=(m+M)u'_1##
But here is the problem. ##u'_1=0##. This means ##u_1=0## which means ##v_1=0##. This is wrong.
What is my mistake?
You have to take care in what system you are considering. If you consider the buggy, there is no force acting on it in horizontal so the velocity remains constant (until the other man comes in). It does not increase.
Part of your problem may also be based in the wording. It is not specified in which frame the jump is perpendicular to the direction of motion. I suspect the intended meaning is in the rest frame of the buggies (otherwise it will be impossible for one buggy to stop).
Likes Abdul wasay and Titan97
I made a mistake. The man acquires a horizontal velocity as well with respect to ground.
So ##(m+M)v_1=Mu_1+mu_1## along horizontal. Hence ##v_1=u_1##.
Yes. Since I took man+buggy as system, there is no change in mass.
But if I take the buggy as the system, initial momentum is zero right? Because with respect to buggy, the velocity of man is zero.
This depends on which system you are considering. With respect to the ground system, this is only true if the initial velocity is zero.
Likes Titan97
Related to Conservation of Momentum: Change in mass
What is the conservation of momentum?
The conservation of momentum is a fundamental law of physics that states that the total momentum of a closed system remains constant over time, unless acted upon by an external force.
How does the conservation of momentum apply to change in mass?
The conservation of momentum applies to change in mass by stating that in a closed system, the total momentum before and after a change in mass remains constant. This means that if one object gains mass, another object in the system must lose mass in order to maintain the same total momentum.
What is an example of the conservation of momentum in relation to change in mass?
One example of the conservation of momentum in relation to change in mass is a rocket launching into space. As the rocket engine burns fuel and ejects it at high speeds, the rocket gains momentum in one direction while the exhaust gases lose momentum in the opposite direction due to the change in mass.
Why is the conservation of momentum important in understanding changes in mass?
The conservation of momentum is important in understanding changes in mass because it helps us predict the motion of objects in a closed system. By considering changes in mass, we can accurately predict the resulting changes in momentum and therefore the resulting motion of objects in the system.
How does the conservation of momentum relate to the law of inertia?
The conservation of momentum is directly related to the law of inertia, which states that an object at rest will remain at rest and an object in motion will remain in motion unless acted upon by an external force. The conservation of momentum explains why objects tend to maintain their state of motion, as any changes in mass or velocity must be balanced by corresponding changes in another object's mass or velocity in order to maintain the total momentum of the system.
