Conservation of Momentum difficulty
In summary: In this case, using "initial" and "final" as I did makes it clear that the system starts with no total momentum and ends with no total momentum, and that the book's change in momentum is equal and opposite to the man's change in momentum.In summary, a man throws his physics textbook at a speed of 5.0 m/s to overcome a lack of friction on a frozen pond. Using the equations p_i = p_f and t = x/v, it is determined that it takes the man 62 seconds to reach the south shore. The initial speed of the book is not 5.0 m/s, as it is assumed that the system starts at rest before the throw.
dontcare
I'm not sure if i did this problem correctly. Could someone check it over.
A 730-N man stands in the middle of a frozen pond of a radius of 5.0 m. He is unable to get to the other side because of a lack of friction between his shoes and the ice. To overcome this difficulty, he throws his 1.2 kg physics textbook horizontally toward the north shore at a speed of 5.0 m/s. How long does it take him to reach the south shore?
[tex] p_i = p_f [/tex]
[tex] 0 = m_1v_1f + m_2v_2f [/tex]
[tex] v_1f = - \frac{m_2}{m_1} * v_2f = - \frac{1.20 kg}{74.5 kg} * 5.0 m/s = -.081 m/s [/tex]
[tex] t = \frac{x}{v} = \frac{5.0 m}{2.46 m/s} = 2.03 s [/tex]
[tex] t = \frac{x}{v} = \frac{5.0 m}{2.46 m/s} = 2.03 s [/tex][/QUOTE]
Corrected:
[tex] t = \frac{x}{v} = \frac{5.0 m}{.081 m/s} = 62 s [/tex][/QUOTE]
dontcare said:
Corrected:
That is correct :smile:
Thank you for checking my problem.
Why is 5.0m/s the final speed of the book but not its initial speed? Wasn't it thrown at a speed of 5.0m/s?
we assume that initially all the system is at rest
so is it wrong to assume that the initial speed of the book is 5m/s?
Yeah, it is. In this case "initial" and "final" mean "before the throw" and "after the throw" respectively.
Of course, there's technically no reason you couldn't pick "initial" and "final" to both be after the throw, but it wouldn't tell you anything useful.
Related to Conservation of Momentum difficulty
1. What is conservation of momentum and why is it important?
Conservation of momentum is a fundamental principle in physics that states that the total momentum of a closed system remains constant unless acted upon by an external force. This means that in a closed system, the total amount of momentum before and after an interaction will be the same. This principle is important because it helps us understand and predict the motion of objects in different situations, such as collisions and explosions.
2. What are some real-world applications of conservation of momentum?
Conservation of momentum has many real-world applications, such as in car accidents, sports, and rocket propulsion. In car accidents, the principle helps us understand the forces involved and how to design safer cars. In sports, momentum plays a crucial role in activities such as throwing a ball or swinging a bat. In rocket propulsion, conservation of momentum is used to explain how rockets are able to move forward in space.
3. Why is it difficult to observe conservation of momentum in everyday life?
In everyday life, it can be difficult to observe conservation of momentum because most objects are constantly experiencing external forces, such as friction and air resistance, which can alter their momentum. Additionally, it is challenging to create a truly closed system in which external forces can be completely eliminated.
4. How can the conservation of momentum be applied to collisions?
In collisions, the total momentum before the collision will be equal to the total momentum after the collision. This allows us to use the principle of conservation of momentum to analyze and predict the outcome of the collision. By using equations and calculations, we can determine the velocities and directions of the objects involved in the collision.
5. Can the conservation of momentum be violated?
No, the conservation of momentum is a fundamental law of physics and cannot be violated. However, in some situations, it may appear that momentum is not conserved. This may be due to external forces that are not accounted for or measurement errors. In reality, the conservation of momentum is always upheld, but it may be difficult to observe or measure accurately in certain cases.
