Conservation of Momentum, dropped vase
In summary, the vase of mass 1/2m falls to the floor and breaks into three pieces. Two of the pieces slide along the floor with a velocity of 20 cm/s. The third piece, of mass 1/4m, moves northeast and the other southeast at a velocity of .14 m/s.
clemsonguy
I've been trying to solve this question for hours now, NEED HELP
You are standing in a shop, holding an expensive vase of mass m. The vase accidentally slips from your hand and falls to the floor. It breaks into three pieces, two of mass 1/4m and one of mass 1/2m. The two pieces of 1/4m slide along the floor with speed v=20 cm/s. If one of these pieces moves east and the other piece moves southeast (i.e. 45 degrees below the +x-axis), what is the velocity (magnitude and direction) of the third piece?
Law of Conservation of Momentum
P=mv
m1v1+m2v2+m3v3=0
I got 0.14m/s for the velocity which I am pretty sure is right. The direction is what I am unsure about. I did get Northeast 45 degrees above x-axis but I think that is wrong. Any help?
Add the momenta of the two small pieces. Clearly it will be in a direction half way between the 0 and -45 degrees of the pieces, so -22.5 degrees. The big piece must go in the opposite direction (add 180 degrees).
I'm not getting .14 for the speed. Best to write your mv + mv = 0 and figure it out carefully. Take the component of each 20 cm/s in the 22.5 degree direction.
22.5 degrees west of north?
For the speed, is this correct?
momentum = (m/2)V
(m/2)V = sq rt[{(m/4)^2}(0.20^2) + {(m/4)^2}(0.20^2) + {2*(m/4)^2}(0.20^2)cos 45]
= sq rt(2)*(m/4)*sq rt[1+cos 45] = sq rt(2)*(m/4)*sq rt[2*cos^2(45/2)] = (m/2)*cos (22.5)
So V = cos(22.5) = 0.9238 m/s
I agree with the 22.5 degrees west of north.
That momentum calc seems unnecessarily complicated. Consider one axis along the combined momentum of the two smaller pieces at 22.5 degrees south of east. The components of momentum in the direction perpendicular to this cancel out. So the momentum of these pieces is 2*.25m*20cos(22.5) and this must be equal to the momentum of the .5m in the opposite direction. So
.5mv = 2*.25m*20cos(22.5)
Intuitively the answer must be not much smaller than 20 cm/s because the cos(22.5) is close to 1.
The 1/2m cancel so v=20cos(22.5). From that I get 18.48 cm/s.
Just to make sure I have done this correctly
X-component:
0 = (.25m)(20) + (.25m)(20)(cos 45) + (.5m)(v3)(cos θ) - (.5m)(v3)(cos θ)
cos θ = (10 + 5sqrt2)/v3
Y-component:
0 = (.25m)(20)(sin 45) +(.5m)( v3)(sin θ) - (.5m)(v3)(sin θ)
sin θ = 5sqrt2/v3
tan θ = (5sqrt2)/(10 + 5sqrt2) = 0.414
θ = inv tan (0.414) = 22.5 degrees
I agree with your 18.48 cm/s and 22.5 degrees.
I did my solution with a different set of axes, so it is difficult for me to check your solution. It looks like you have 4 moving objects in the first line of your solution for the x component, which doesn't seem right. Probably a typo; getting the same answers two different ways strongly suggests both are correct.
Related to Conservation of Momentum, dropped vase
1. What is the principle of conservation of momentum?
The principle of conservation of momentum states that the total momentum of a closed system remains constant over time, regardless of any internal or external forces acting on the system.
2. How does the conservation of momentum apply to a dropped vase?
When a vase is dropped, it falls due to the force of gravity and gains momentum. However, as the vase hits the ground and shatters, the pieces have less momentum due to the loss of energy in the form of sound and heat. The total momentum of the system (vase + Earth) remains constant, but the momentum is transferred from the vase to the ground and air.
3. Why is the conservation of momentum important in understanding the motion of objects?
The conservation of momentum is important because it allows us to predict the motion of objects in a closed system. By understanding how the momentum of objects is transferred and conserved, we can make accurate predictions about their motion and interactions.
4. Does the conservation of momentum apply to all types of collisions?
Yes, the conservation of momentum applies to all types of collisions, including elastic and inelastic collisions. In elastic collisions, the total kinetic energy is conserved along with the total momentum. In inelastic collisions, some kinetic energy is lost, but the total momentum remains constant.
5. Can the conservation of momentum be violated?
No, the conservation of momentum is a fundamental law of physics and cannot be violated. In a closed system, the total momentum will always remain constant, even if individual objects within the system exchange momentum with each other.
9K
