Conservation of momentum & energy
In summary, the conversation discusses the use of conservation of momentum and energy in problems involving electricity. It is generally true that conservation of momentum is used when two objects are moving and conservation of energy is used when one object is at rest. However, there are exceptions to these rules and it is best to practice solving problems to gain a better understanding. It is important to consider all conservation laws when solving a problem and it is unlikely to get two different answers as long as the problem is interpreted correctly.
downtime91
Good evening phsyicsforum. I am having a lot of trouble finding out what must be true for me to use conservation of momentum or energy (sometimes both) in problems involving electricity. Below I will post 2 different questions and what they conservation they use.
1. Find the initial velocity of an alpha particle with a mass of 6.64 x 10^-27 kg and a charge of +3.2 x 10^-19 C, if it undergoes a head-on "collision" with a gold nucleus. You may assume the gold nucleus does not move at all during the interaction. The charge on the gold nucleus is +2.53 x 10^-17 C and the distance of closest approach between the two is 4.7 x 10^-15
2. An alpha particle moving at 3.0 x 10^6 ms [east] (m2= 6.64 x 10^-27 kg and q2= +3.2 x 10^-19 C) is headed directly towards a proton moving at 5.0 x 10^6 m/s [west] (m1= 1.67 x 10^-27 kg, q1 = 1.6 x 10^-19 C). Find the distance of closest approach assuming that they start from a very far apart position.
Pto=Ptf
Eto=Etf
Now I don't want any help answering the question itself because that is quite easy. I am only having trouble deciding when it is true to use conservation of momentum or energy or both.
Do I only use conservation of momentum when 2 objects are moving? And is conservation of energy used when only one object is moving and 1 is at rest?
Generally, that's true. The conservation laws are of course always true, it's just a matter of whether the variables they open up allow you to solve for desired quantities. For example, in the first problem, conservation of momentum is true and can be used, but it's not going to get you anywhere. You can know that the initial momentum equals the final momentum, so initial velocity equals final velocity, and you don't know either. So in that case you would look to energy conservation.
And there are of course some exceptions to those rules. Consider this situation: two blocks travel at different velocities along a frictionless surface. The block in front travels slower, and has a spring attached to one side of it, facing the other block, which is moving faster. To solve for things here, there's both momentum conservation and energy conservation.
Most important I think is to just do a lot of problems, and you can start to feel which laws will be most helpful based on the scenario.
Ok thanks a lot for your input jackarms. I have a question to ask back to you. Let's say for a question that didn't really require conservation of momentum and you could just use conservation of energy. If I solved using both conservation of momentum and energy, would it affect my answer? or would I get the same answer, just with a lot more steps?
No, as long as you don't misinterpret anything in the problem, you'll never get two different answers with two logical sequences of steps. And in almost all cases problems can't be solved using either law, and it's much more common that both laws are required. The only case I can think of where either would work would be a problem where only kinetic energy is involved -- kinetic energy tends to be the link between energy and momentum. If you throw potential energy in the mix, that can only be explained by energy, except in special cases.
Hope this has helped at least a bit. I'd say the best thing to do for any problem is to consider conservation of anything you can think of and see where it get you.
I would like to clarify that conservation of momentum and energy are fundamental principles in physics that apply to all systems, not just those involving electricity. These principles state that the total momentum and energy of a closed system remain constant in the absence of external forces or energy transfers.
In the first question, the interaction between the alpha particle and gold nucleus can be considered a closed system, as no external forces or energy transfers are involved. Therefore, both conservation of momentum and energy can be applied to solve for the initial velocity of the alpha particle.
In the second question, the system of the alpha particle and proton can also be considered a closed system. However, since the alpha particle and proton are already in motion, conservation of momentum can be used to determine the distance of closest approach.
In general, conservation of momentum applies to systems involving multiple objects in motion, while conservation of energy applies to systems involving energy transfers or changes in energy. However, both principles can be used in combination to solve for unknown quantities in various scenarios. It is important to carefully analyze the system and determine which principle(s) is applicable.
Related to Conservation of momentum & energy
1. What is the law of conservation of momentum and energy?
The law of conservation of momentum and energy states that the total momentum and energy of a closed system remains constant over time, regardless of any internal changes or interactions within the system.
2. Why is the conservation of momentum and energy important?
The conservation of momentum and energy is important because it is a fundamental law of physics that helps us understand and predict the behavior of objects and systems. It is also crucial in various applications such as engineering, astrophysics, and everyday life.
3. How does the conservation of momentum and energy apply to collisions?
In a collision between two objects, the total momentum and energy of the system before and after the collision must be equal. This means that the objects involved in the collision will exchange momentum and energy, but the overall values will remain constant.
4. Can the law of conservation of momentum and energy be violated?
No, the law of conservation of momentum and energy is a fundamental law of physics and has been extensively tested and proven to hold true in all known cases. Any apparent violations are usually due to incomplete or inaccurate measurements.
5. How is the conservation of momentum and energy related to Newton's laws of motion?
The law of conservation of momentum is a direct result of Newton's third law of motion, which states that for every action, there is an equal and opposite reaction. Meanwhile, the law of conservation of energy is tied to the first and second laws of motion, which describe the relationship between forces, mass, and acceleration.
