Conservation of momentum for accelerating object
In summary, the conversation discusses the formula for momentum and how it relates to the conservation of momentum in collisions. The formula for momentum is mv, where m is the mass and v is the velocity. This formula is valid for both elastic and non-elastic collisions. It is also mentioned that for a collision to be elastic, the kinetic energy must be conserved. The conversation also touches on external forces and their impact on the conservation of momentum, as well as the role of acceleration in collisions.
terryds
392
I always see that a ball moving in a constant speed collide with another ball is common conservation of momentum problems. Obviously, I know that the momentum is mass*velocity
But, what if the ball accelerates and collides with another ball ?
I think I can't use mass*velocity for the momentum because the velocity is not constant.
Then, I think that I might have missed the Δ symbol.
Because I think that the conservation of momentum is derived like below.
F = -F
m Δv/Δt = m Δv/Δt
Because the object A contacts object B at the same time as the object B contacts object A, so we can cancel Δt
So, m Δv = m Δv
So, is the formula m Δv ?
But, I doubt it, because I think non-accelerating objects which has Δv = 0 since its velocity doesn't change also have momentum
Or, maybe the formula is mass times the velocity the object has when contacting another object.
But, I don't know how to derive the formula (p = m*v) since F = ma = m Δv/Δt has a delta symbol and momentum formula doesn't have delta symbol.
So, What is the momentum formula ?
Is it mass times the velocity the object has when contacting another object or m v ?
Or is it m Δv ?
If the formula is m v , Please tell me how to derive that formula.
The momentum is mv. If the velocity increases (the body is accelerating) the momentum increases too. This is what Newton's second law states (in the momentum format): if there is net force acting on the system, the momentum changes (F=Δp/Δt).
The momentum is conserved only if the net force is zero. If there is a non-zero net force, the momentum is not conserved, of course.
So for the collision described, if there is an external force acting on one or both colliding bodies, the momentum is not conserved. By external force I mean a force which is not due to the interaction between the colliding bodies but interaction with other bodies, not participating in the collision.
However, as the collision time is (usually) very short it may be possible to neglect the change in total momentum that occurred during the collision. It depends on the problem if you can or cannot do this.
Delta means difference. The difference of two momentum quantities is still a momentum. Just like the difference of two lengths is still a length.
If just the two balls are involved, the law of conservation of momentum reads mAvA = mBvB.
This law is valid whether the impact is elastic or non-elastic. Also observe that Newton's original formula reads [itex]\frac{d(mv)}{dt}= \frac{dm}{dt}\cdot v + m\cdot \frac{dv}{dt} [/itex]. Usually the mass is constant, so [itex]\frac{dm}{dt} = 0 [/itex]. When your you are dealing with rockets, you need the complete formula (the mass decreases as the fuel is used up).
Suppose ball A is accelerating and going to hit ball B which is static. And, both balls have the same mass, and the collision is elastic
After the collision, the acceleration of the ball B is the same as the initial acceleration of the ball A, right ?
And, after the collision, ball A's acceleration is the same as B but, with opposite direction, right ?
The contact force is mass * the acceleration the ball A has before collision, right ?
I think there is no external force when the ball is moving. The external force is just to get the ball moving (accelerate).
None of the relevant laws say anything about acceleration. Use the "conservation of momentum" formula. In addition, for an elastic collision, the kinetic energy is conserved.
You seem to confuse acceleration and velocity.
FAQ: Conservation of momentum for accelerating object
What is the conservation of momentum for accelerating objects?
The conservation of momentum for accelerating objects is a fundamental law of physics that states that the total momentum of a system remains constant in the absence of external forces. This means that the total mass and velocity of a system will remain constant unless acted upon by an external force.
How is momentum calculated for an accelerating object?
Momentum is calculated by multiplying the mass of an object by its velocity. For an accelerating object, the velocity can change over time, so the momentum can also change. However, the total momentum of the system will remain constant as long as there are no external forces acting on the system.
How does conservation of momentum apply to collisions?
In collisions, the total momentum of the system is conserved, meaning that the sum of the momentums of all objects involved in the collision before and after the collision will be equal. This allows us to use the conservation of momentum to calculate the final velocities of the objects after the collision.
What are some real-life examples of conservation of momentum for accelerating objects?
Some real-life examples of conservation of momentum for accelerating objects include rocket launches, car crashes, and sports such as ice skating and diving. In each of these scenarios, the total momentum of the system remains constant, even as individual objects within the system may change their velocities.
How does the conservation of momentum affect the motion of objects in space?
The conservation of momentum is crucial in understanding the motion of objects in space. In the absence of external forces such as gravity, the total momentum of a system will remain constant, allowing us to predict the trajectories and velocities of objects in space. This principle is also essential for spacecraft maneuvers and orbital mechanics.
