B Conservation of momentum in a closed system
In a closed system of particles undergoing elastic collisions, conservation of momentum and kinetic energy suggests that particles will continue to move apart indefinitely. When particles are displaced from the center of mass, their momentum can lead to a scenario where they drift away from each other forever, regardless of their initial conditions. The discussion highlights that even when particles collide, they bounce off each other while conserving momentum and energy, maintaining the outward expansion. Additionally, the analogy to gas behavior indicates that the system must exert pressure if contained, or expand if uncontained. Overall, the principles of classical mechanics imply a continuous outward movement of particles in such a system.
bobdavis
In a closed system consisting of a set of particles not at rest relative to each other and acting on each other only by classical mechanical collision (i.e. billiard balls model, not including gravity or other long-range interactions), does conservation of momentum imply that the system will expand outward forever? If so how would I show this and if not can a counterexample be provided?
EDIT: In particular I mean elastic collisions, so not just momentum but also kinetic energy is conserved, and the "not at rest relative to each other" criteria is just non-zero kinetic energy, otherwise a counterexample would be two particles of opposite momentum in inelastic collision such that they both stop.
Attempt at answering: my intuition is that a component of the momentum of the center of mass might at a given time correspond to the kinetic energy of particles that are displaced from the center of mass in the opposite direction as that component, but because momentum and kinetic energy are both conserved, this kinetic energy will eventually propagate in the direction of that component until it reaches the other side, i.e. until its displacement from the center of mass is in the same direction as the component of momentum, and once this is true for all the kinetic energy in the system then you would just have a radially expanding system with particles heading away from the origin forever.
Two examples to clarify:
1) Two particles displaced from the center of mass in the same direction as their momentum: the particles simply drift away from each other forever.
2) Two particles displaced from the center of mass in the opposite direction as their momentum: the particles collide at the center of mass, but kinetic energy and momentum are conserved so the particles bounce off each other and now the situation is the same as (1) and so the particles now drift away from each other forever.
The system is effectively a gas of particles and must exert some pressure on the walls of any container. If there is no container, then the pressure must gradually decrease and the volume increase. In other words, if the gas has internal KE then it cannot be pressureless.
That's one way to look at it.
Likes vanhees71 and bobdavis
I see. When I posted the question I was just thinking in terms of a regular mechanical system and I didn't make the connection to kinetic theory of gases but now I know where to look for more insight, thank you
Likes vanhees71, berkeman and PeroK
If the particles are all identical point particles with equal mass, can this be extended to a stronger statement that the evolution of the system is described by the rays extending from the initial velocity vectors of the particles? i.e. for each particle with initial position p and initial velocity v, at any time t > 0 there will be a particle with position p+vt and velocity v ? ex.. if the particle never collides with any other particles, then this particle will satisfy the criteria at every time t, and if the particle does collide with another particle then second particle will acquire the velocity of the first and traverse the next section with the same velocity v until the next collision and so on (the same as if the particles had just passed through each other without interacting, so the point of collision is just a point of intersection of the trajectory rays)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
