Conservation of Momentum or Energy in a collision?
In summary, the collision between the ball and pendulum is completely inelastic, meaning that energy is not conserved during the collision. However, momentum or angular momentum is conserved. After the collision, the pendulum and ball will rise to a height of approximately 0.022 meters.
Striders
23
A ball with mass 2kg is traveling 2m/s. It impacts and sticks to a hanging, stationary 4kg pendulum. How high will the pendulum + ball go?
KE = 1/2mv2
PEg = mgh
mava = m(a+b)v(a+b)
I tried to solve this question assuming conservation of energy in the collision, while a friend tried to solve it using conservation of momentum, and we got two separate answers. The question itself dos not say whether the collision is elastic or inelastic (is there some way to figure it out from the given information?).
My attempt:
Let the ball be represented by a
Let the ball + pendulum be represented by (a+b)
KEa = PEga+b
1/2mava2 = m(a+b)gh
1/2(2)(2)2 = 6gh
4 / 6g = h
0.066 = h
My friend's attempt:
mava = m(a+b)v(a+b)
2(2) = 6V(a+b)
V(a+b) = 2/3
KE(a+b) = PEg(a+b)
1/2m(a+b)v(a+b)2 = 6gh(a+b)
1/2(6)(2/3)2 = 6gh
1.33 = 6gh
1.33/6g = h
0.022 = h
Neither of us can see where the other went wrong; can someone please shed some light on which way is correct?
The question states that the ball "impacts and sticks", which automatically makes the collision inelastic. Conservation of energy does not work for inelastic collisions.
Thanks, that's pretty clear-cut. A few followup questions:
1) I had been under the impression that the sole criterion for a collision to be considered inelastic is that there is some permanent deformation of the objects involved. Is that incorrect? Or is it correct and the sticking together of the ball and pendulum is considered a 'deformation'?
2) The difference in height is a factor of 3 between our answers. Interestingly, this is the same as the difference between the ball's mass and the ball + pendulum's mass. Is there a generalizable relationship between the mass of the pre-collision object, the mass of the post-collision object, and the energy lost in the collision? Like energy pre-collision / energy post-collision = mass pre-collision/mass post-collision?
3) The principle of conservation of energy must still hold true, I'd imagine. So that means the 2/3rds of the ball's kinetic energy that are not in the ball + pendulum's potential gravitational energy have gone... somewhere. Do they just dissipate as sound and heat in the collision? Or is there some other mechanism by which energy is not conserved during inelastic collisions?
Thanks a bunch!
Needn't be permanent. There's mechanical energy lost every time you hit a tennis ball.
You could obtain some general rule for simple linear collisions, but here there's rotation involved.
Edit: Rereading the question, it is effectively a simple linear collision here.
Yes.
There is a range of collisions between "perfectly elastic" and "perfectly inelastic" where energy can be lost to different processes, including deformations. When you have a chance, look up the "coefficient of restitution".
Sounds like something you could investigate using the equations for collisions. I haven't looked into it myself.
Energy will find its way to any process it can reach. Sound and heat are typical sinks, but other mechanical vibrations or displacements/compressions are possible too. If there's magnetic or electric fields involved they can act as a way to move energy around too. In the end though, pretty much all the lost energy will degrade to waste heat unless it is somehow directed into a potential energy form (for example a collision might power a small generator and store a charge on a capacitor, or move a piston to compress a gas).
KE = 1/2mv2
PEg = mgh
mava = m(a+b)v(a+b)
My attempt:
KEa = PEga+b
1/2mava2 = m(a+b)gh
1/2(2)(2)2 = 6gh
4 / 6g = h
0.066 = h
The ball sticks to the pendulum, so the collision is completely inelastic. The initial PE of the ball is not the same as the final PE of the ball+pendulum. Your approach is wrong. .
mava = m(a+b)v(a+b)
2(2) = 6V(a+b)
V(a+b) = 2/3
That is correct. The momentum or angular momentum conserves during the collision.
After the collision, the energy conserves during the motion of the pendulum.
Striders said:
KE(a+b) = PEg(a+b)
1/2(6)(2/3)2 = 6gh
1.33 = 6gh
1.33/6g = h
0.022 = h
The unit (m) is missing, otherwise it is correct.
Yes. You should be able to prove this yourself:
If ##m_1## is the incident mass and ##m_2## is the (stationary) target mass, show that the proportion of kinetic energy retained in a perfectly inelastic collision is ##\frac{m_1}{m_1 + m_2}##
Related to Conservation of Momentum or Energy in a collision?
What is the law of conservation of momentum or energy in a collision?
The law of conservation of momentum states that in a closed system, the total momentum before a collision is equal to the total momentum after the collision. Similarly, the law of conservation of energy states that in a closed system, the total energy before a collision is equal to the total energy after the collision.
What is an elastic collision?
An elastic collision is a type of collision in which both momentum and kinetic energy are conserved. This means that the total momentum and total energy of the system remain the same before and after the collision.
What is an inelastic collision?
An inelastic collision is a type of collision in which total momentum is conserved, but kinetic energy is not. This means that the total momentum of the system remains the same, but some of the kinetic energy is lost and converted into other forms of energy, such as heat or sound.
How does the mass of an object affect conservation of momentum or energy in a collision?
The mass of an object does not affect the conservation of momentum or energy in a collision. The law states that the total momentum or energy of the system will remain the same, regardless of the masses of the objects involved. However, the individual velocities of the objects may be affected.
What is the difference between an inelastic collision and a completely inelastic collision?
In an inelastic collision, some kinetic energy is lost and converted into other forms of energy. In a completely inelastic collision, all of the kinetic energy is lost and the objects stick together after the collision. This means that the final velocity of the objects will be the same, and the objects will move as one combined mass.
9K
