Conservation of momentum problem regarding a missing mass of a ship
In summary, after a malfunction on a spaceship, an astronaut escapes using an escape pod that is blown off the ship, with the pod moving at 34.9 m/s and the spaceship moving in the opposite direction at 1.89 cm/s. Using the conservation of momentum principle, we can determine that the initial velocities for both the ship and the pod were 0, and therefore the combined mass of the astronaut and pod (1270 kg) is also the mass of the doomed spaceship.
MichaelDunlevy
After a malfunction, an astronaut escapes from a doomed spacecraft by using an escape pod that is blown off of the ship. The small explosion sends the pod flying away at 34.9 m/s, while the main ship moves in the opposite direction at the speed of 1.89 cm/s. If the combined mass of the astronaut and pod is 1270 kg, what is the mass of the doomed spacecraft ?
Conservation of Momentum:
m1u1+m2u2 (initial) = m1v1+m2v2 (final)
I believe that conservation of momentum is the correct principle to use here, but I am unsure how to solve for the spaceship's mass because of the missing initial velocity. Could someone help me out? Thanks!
Hi there!
The initial velocity was meant to be 0 for both the ship and the pod.
Those velocities provided are for after the separation, relative to their mutual centre of mass.
If the spaceship and pod before the launch had 0 momentum to their mutual centre of mass, the conservation of momentum says:
the pod and spaceship must have right after the launch 0 momentum to their mutual centre of mass. So you have 4 variables ( as intial velocities were both 0 ) after the launch; ( mass and velocity of spaceship and pod ).
thank you! i figured that the velocity must have been an unknown constant (which would be ridiculous) or 0. I just wanted verification. Thank you for the fast reply guys!
You are correct in using conservation of momentum to solve this problem. In order to solve for the mass of the spaceship, you will need to use the equation m1u1+m2u2 = m1v1+m2v2, where m1 and u1 represent the mass and initial velocity of the astronaut and pod, and m2 and u2 represent the mass and initial velocity of the spaceship. Since the initial velocity of the spaceship is missing, we can use the fact that the total momentum before and after the explosion must be equal, and set the initial momentum (m1u1+m2u2) equal to the final momentum (m1v1+m2v2). This will allow us to solve for the missing mass of the spaceship. So, we have:
(1270 kg)(34.9 m/s) + m2(1.89 cm/s) = (1270 kg)(0 m/s) + m2(0 m/s)
44273 kg*m/s + 0.0189 m2/s = 0 kg*m/s + 0 kg*m/s
44273 kg*m/s = 0.0189 m2/s
Solving for m2, we get:
m2 = (44273 kg*m/s) / (0.0189 m/s)
m2 = 2.34 x 10^6 kg
Therefore, the mass of the spaceship is approximately 2.34 x 10^6 kg.
Related to Conservation of momentum problem regarding a missing mass of a ship
1. What is the conservation of momentum principle?
The conservation of momentum principle states that the total momentum of a closed system remains constant. This means that in a system where no external forces are acting, the total momentum before and after an event will be the same.
2. How does the conservation of momentum apply to a missing mass of a ship?
In the case of a missing mass of a ship, the conservation of momentum principle can be used to determine the velocity of the missing mass. By considering the momentum of the entire ship before and after the event, the velocity of the missing mass can be calculated.
3. What factors affect the conservation of momentum in a ship?
The conservation of momentum in a ship can be affected by various factors such as the mass and velocity of the ship, any external forces acting on the ship, and any changes in the mass distribution within the ship.
4. How does the conservation of momentum impact the stability of a ship?
The conservation of momentum is an important principle in ship stability as it helps to determine the forces and moments acting on the ship. By ensuring that the total momentum of the ship remains constant, the stability of the ship can be maintained.
5. How can the conservation of momentum principle be applied to real-life ship accidents?
In real-life ship accidents, the conservation of momentum principle can be used to analyze the events leading up to the accident and determine the cause. By considering the momentum of the ship before and after the accident, the velocity of the missing mass or any external forces can be calculated to understand the dynamics of the accident.
