Conservation of momentum (relative speed)
In summary, by applying conservation of momentum, it can be shown that the shell's speed relative to the ground is equal to the bullet's speed relative to the gun divided by the sum of the bullet's mass and the gun's mass.
weirdlycool
Consider a gun of mass M (when unloaded) that fires a shell of mass m with muzzle speed v. (That is, the shell's speed relative to the gun is v.) Assuming that the gun is completely free to recoil (no external forces on gun or shell), use conservation of momentum to show that the shell's speed relative to the ground is ##\frac{v}{(1+ \frac{m}{M})}##
##p=mv##
##m_1 v_1 = m_2 v_2##
##M = ## mass of the gun
##m = ## mass of the shell
##v = ## speed of the shell relative to the gun's muzzle
##v_g = ## shell's speed relative to the ground
##p_{initial} = Mv##
##p_{final} = ( M + m ) v_g##
I'm not sure if the initial and final momentum is correct
##Mv = ( M + m ) v_g##
##v = (1 + \frac{m}{M}) v_g ##
##v_g = \frac{v}{(1+ \frac{m}{M})}##
Your equation is wrong.
Likes weirdlycool
In conservation of momentum, you have to always identify first what is the initial state and the final state then you will know how to construct the initial and final momentum. Now, the initial state is when you are NOT yet firing the gun then the final state is when you already fired the gun with the bullet having a speed v. So, what is your initial momentum given that you haven't fired the gun yet? Also after firing, is the bullet and gun together? You should also construct the relationship of the velocities in vector form.
v(gun rel ground) + v(bullet rel gun) = v(bullet rel ground)
Likes weirdlycool
Thanks, I think I got it already. The initial momentum is 0
## p_{initial} = ## 0
## p_{final} = ## M v(gun rel ground) + m v(bullet rel ground) therefore,
0 = M [ v(bullet rel ground) - v(bullet rel gun) ] + m v(bullet rel ground)
m v(bullet rel ground) = - M v(bullet rel ground) + M v(bullet rel gun)
( m + M ) v(bullet rel ground) = M v(bullet rel gun)
## v(bullet \ rel \ ground) = \frac{v(bullet \ rel \ gun)}{(\frac{m}{M}+1)}##
That's right.
Likes weirdlycool
Related to Conservation of momentum (relative speed)
1. What is the concept of conservation of momentum?
The conservation of momentum is a fundamental principle in physics that states that the total momentum of a closed system remains constant. This means that the total momentum before an event, such as a collision, is equal to the total momentum after the event, regardless of any internal forces or interactions.
2. How does conservation of momentum relate to relative speed?
Relative speed is the difference in speed between two objects, usually measured in terms of their velocities. The conservation of momentum applies to all objects in a closed system, regardless of their relative speeds. This means that the total momentum of the system will remain constant, regardless of how the individual objects' speeds change.
3. What is an example of conservation of momentum in real life?
A classic example of conservation of momentum is when two billiard balls collide on a billiard table. The total momentum before the collision (the combined momentum of both balls) is equal to the total momentum after the collision. This is because the force of one ball hitting the other is equal and opposite, resulting in the total momentum remaining constant.
4. How does conservation of momentum affect rocket launches?
Conservation of momentum plays a crucial role in rocket launches. When a rocket launches, it expels hot gases at high speeds in one direction, resulting in a reaction force that propels the rocket in the opposite direction. This demonstrates the conservation of momentum, as the total momentum of the rocket and expelled gases remains constant.
5. What happens when the conservation of momentum is violated?
If the conservation of momentum is violated, it means that the total momentum of a closed system is not constant. This would go against the fundamental laws of physics and could have significant consequences. In most cases, however, it is due to external forces acting on the system, and the principle of conservation of momentum still holds true.
9K
