Conservation of Momentum vs Energy
In summary, the conversation discusses a setup with a horizontal rod and two disks that are perfectly balanced and free to rotate. Two point masses collide with the setup and stick to it, resulting in two different cases. In case 1, the point masses hit the rod at equal distances from its center of mass, while in case 2, they hit the disk edges equidistant from the center of mass. The system's velocity along the y-axis is discussed and it is questioned whether it would be the same in both cases. The conclusion is that inelastic collisions result in some of the energy being converted into internal energy, making it impossible to use conservation of kinetic energy. Therefore, the linear velocity along the y-axis would be the same in
Student149
58
Given a horizontal rod (parallel to x axis) and two disks attached near its ends symmetrically. The rods and disks are perfectly balanced i.e. the disks have same mass and density. The system's center of mass is exactly at geometric center of the rod (since its balanced). The disks are attached at their center with the rod and are free to rotate about the pivot point parallel to x axis. The complete setup is at rest in space w.r.t. to the external observer.
There are two point masses (each with mass = m0) that are traveling towards the rod parallel to y-axis at a velocity v0. They stick to the setup after the collision.
Now consider two cases:
Case 1: The 2 point masses hit the rod at equal distance from its center of mass. They stick to the rod after collision. The combined system has a linear velocity = v1 along y axis.
Case 2: The 2 point masses hit the disk's edges equidistant from the center of mass of the whole system. They stick to the disk edge after collision. The point of contact is such that one disk rotate in opposite direction (one clockwise another anticlockwise) with equal velocity.The system thus, still has net 0 angular momentum. The combined system has a linear velocity = v2 along y axis.
Would the velocity of the system be same in both cases along y-axis as seen by the external observer?
My understanding is as some of the energy is used in disk rotation in case 2 when the to point masses collide with the system, where as in case 1 all energy is used in head on collision in y axis. Thus, the velocity of the system in case 2 would be lesser than the velocity of the system in case 1.
But, if conservation of momentum is taken literally, no matter where the 2 point masses hit the system (such that they are equidistant from center of mass of the system), the velocity of the system along y-axis would be same. Thus, case 1 and case 2 both would have same velocity along y axis.
They seem to be contradictory. Which line of argument is correct and why?
This means that the collision is inelastic, i.e., some of the energy is converted into internal energy (e.g., in the form of heat). It is therefore not possible to use conservation of kinetic energy.
Thank you. So as I understand in case of inelastic collisions as above, the linear velocity should be same (as in the above setup) along y axis, no matter where the point masses make contact with the setup (either disk or rod) ?
And the above would also be true if the setup was making some angle w.r.t. the x-axis to begin with (the angle is w.r.t. the center of mass of the rod/setup) ?
Just from conservation of total momentum (assuming no external forces), the centre of mass of the objects always travels at the same velocity.
Related to Conservation of Momentum vs Energy
What is the difference between conservation of momentum and conservation of energy?
Conservation of momentum states that the total momentum of a closed system remains constant, while conservation of energy states that the total energy of a closed system remains constant. In other words, momentum is the product of mass and velocity, while energy is the ability to do work.
Can conservation of momentum and conservation of energy be applied to all systems?
Yes, both principles can be applied to all systems. However, they are most commonly used in closed systems, where there is no external force acting on the system.
How are conservation of momentum and conservation of energy related?
Conservation of momentum and conservation of energy are related in that they both describe fundamental principles of physics that govern the behavior of closed systems. In many cases, the conservation of momentum and energy laws are used together to solve complex problems in physics.
Which principle is more useful in solving real-world problems?
Both conservation of momentum and conservation of energy are equally useful in solving real-world problems. The choice of which principle to use depends on the specific system and problem being studied.
Can conservation of momentum and conservation of energy be violated?
No, both principles are fundamental laws of physics and have been extensively tested and proven. While they may appear to be violated in certain situations, further analysis often reveals that other factors were at play, such as external forces or energy transformations within the system.
9K
