Conservation of Momentum with Friction?
In summary: In that case the momentum of the upper block would be reduced to zero when it came to rest relative to the lower block because the lower block would have caught up to and stopped it.
Robzoid
When reading lessons on the conservation of momentum, you usually see examples with colliding balls or something to that effect. These examples always seem to fail to mention friction. These balls will always come to a stop due to friction. How is momentum conserved when it is lost to friction? In a system of with an initial net momentum, where does the momentum go once the momentum of all the macro-cosmic objects is reduced, by friction, to 0?
I know momentum is conserved for closed systems. Many people might simply say that the friction is an external force. However, you should be able to choose your system so that it includes the source of friction.
Part of me wants to say that the momentum dissipates into the microscopic movement of the atoms in the surface which caused the friction. However, I've also heard that the momentum vector of atoms cancel out as a result of friction.
Any help will be greatly appreciated it. I've been racking my brain about this one for the past few days.
If you don't consider friction as an external force, then the Earth must be considered as part of your system. Momentum of the object that is lost is gained by the earth, speeding it up by a wee bit. Otherwise, if you don't consider the Earth as part of the system, momentum is not conserved when friction or any external force is acting, rather, momentum is changed , per Newtons 2nd law.
Likes Robzoid
Consider two blocks, one on top of the other. Initially the lower block is at rest and the upper block is sliding along the top surface of the lower block. Three is a force from friction acting to slow the upper block. But by Newton's third law there is an equal and opposite force on the lower block so it accelerates. Thus when the upper block comes to rest relative to the lower block neither block is at rest; both are moving at the same speed and their combined momentum is equal to the initial momentum of the upper block.
That's a closed-system analysis. If the mass of the lower block is very much larger than that of the upper block (for example, the lower block is the planet Earth and the upper block is some object that I've been carrying around) it's easier to consider the lower block as immobile and treat the upper block as an open system.
Likes Robzoid
Related to Conservation of Momentum with Friction?
1. What is the law of conservation of momentum with friction?
The law of conservation of momentum with friction states that the total momentum of a system remains constant as long as there are no external forces acting on the system. This means that the initial momentum of a system, including any frictional forces, must be equal to the final momentum of the system.
2. How does friction affect conservation of momentum?
Friction, as an external force, can cause a change in the total momentum of a system. This is because friction acts in the opposite direction of the object's motion, slowing it down and reducing its momentum. However, the total momentum of the system is still conserved, as the frictional force is accounted for in the overall calculation.
3. Can friction ever increase momentum in a system?
No, friction can never increase momentum in a system. Friction always acts in the opposite direction of motion, therefore it always decreases the total momentum of a system. This is in accordance with the law of conservation of momentum, which states that momentum cannot be created or destroyed.
4. How does the coefficient of friction affect conservation of momentum?
The coefficient of friction is a measure of the amount of friction between two surfaces. The higher the coefficient of friction, the greater the frictional force and the greater the impact on conservation of momentum. This is because a higher coefficient of friction results in a greater decrease in momentum due to friction.
5. Are there any real-world applications of conservation of momentum with friction?
Yes, conservation of momentum with friction has many real-world applications. For example, it is used in car collisions to determine the forces involved and in sports such as ice skating and skiing to control speed and direction. It is also important in engineering and design, as engineers must account for frictional forces in order to ensure the safe and efficient operation of machinery and structures.
  • Mechanics
14K
