mathchimp
- 5
I just want to state that i DID solve the problem. I just seek understanding of it.
I'd be really grateful if someone could answer two of my questions at the end of this post. The problem I've solved here is just to show what I'm dealing with.
1. Homework Statement
Object 1 is moving towards object 2 with a velocity of v1=10m/s.
Object 2 is standing still.
Mass of object 1 is m1=4kg, and for object 2 it's m2=2kg.
If all kinetic energy is conserved after collision, determine v1f and v2f (final velocities).
So far, what I know:
CONSERVATION OF MOMENTUM:
m1*v1+m2*v2 = m1*v1f+m2*v2f
CONSERVATION OF KINETIC ENERGY (in this case all of it is conserved)
1/2*(m1*v1^2)+1/2*(m2*v2^2) = 1/2*(m1*v1f^2)+1/2*(m2*v2f^2)
What first I did was use the equation for conservation of momentum:
Using this equation, and assuming that all kinetic energy was conserved, using
I get two equations, two unknowns, and end up with:
2*1v1f+v2f = 20
2*v1f^2 + v2f^2 = 200
I plugged v2f into the second equation and ended up with 2 solutions:
v1f = 10m/s or 3.33 m/s
In which case I get
v2f = 0 or 13.34 m/s
There are 2 things that confuse me:
1) How do I actually pick the right velocity? In this case, v1f=3.33 and v2f=13.34 makes more sense to me (and it is the right answer), but I'm unsure how to explain it "physically". Is a good way to do this to just plug the solutions into the formula for coefficient of restitution and see whether it makes sense? I get 1 for the right solution here and -1 for the other one, can I conclude the other one isn't possible because they wouldn't actually hit each other (and e=1 means it's an elastic collision)?
2)In our physics class, the teacher encourages us to use the conservation of momentum formula which would, if these objects were moving one towards another, look like this:
m1*v1-m2*v2 = -(m1*v1f+m2*v2)f
Does it matter if I use the equation above or the other one I've solved my problem with?
I've actually done quite a number of these problems and it always somehow turns out to be unimportant. Obviously, if one object is moving to the left, its velocity is negative, so I'd just plug in a negative value, but in that case I'm getting something like:
m1*v1-m2*v2 = m1*v1f+m2*v2f
Which is, well... a different equation. They usually don't trouble us with getting the direction of these objects in the end (negative or positive velocities, doesn't matter) but I'm wondering if both would provide me with correct (identical) answers.
2*1v1f+v2f = 20
In which case I get
