Conservation of String Exercise
The discussion focuses on applying the conservation of string principle to a problem involving a symmetric sub-pulley. Participants emphasize that the string's length remains constant, which leads to equations relating the vertical positions of the masses and the pulley. They suggest differentiating these equations to derive relationships for velocities and accelerations. A key point is that the acceleration of the left mass is the negative average of the accelerations of the right two masses, highlighting the interconnectedness of the system. Overall, the conversation aims to clarify the application of these concepts in solving the problem effectively.
mancity
Explain why the acceleration of the left mass equals negative the average of the accelerations of the right two masses.
Conservation of string
I'm not quite sure how to apply conservation of string to this problem, so guidance would be appreciated. Normally as long as there isn't a "sub-pulley" I can do the problem fairly easily but this one tricks me up. Thanks
The sub-pulley is symmetric, correct? That is, there is no difference between its right and left hand sides? They are mirror images of each other?
I take the masses as unknown.
Write equations relating string (section) lengths to heights of masses, throwing in constants as necessary. Differentiate twice.
mancity said:
Homework Statement: Explain why the acceleration of the left mass equals negative the average of the accelerations of the right two masses.
Relevant Equations: Conservation of string
'Conservation of string' is an unusual way to state that the length of the string is constant. So when you set up a set of equations for your exercise, one of them is a relationship between
##y_2##, the vertical position of the middle mass,
##y_3##, idem rightmost mass
##y_5##, the vertical position of the center of the pulley on the right:
##y_5-y_2+y_5-y_3=C##
Differentiation wrt time gives an equation for the vertical velocities; a second differentiation yields another for the accelerations.
Relative to the bottom pulley, the average acceleration of the bottom two masses is zero. The acceleration of the upper mass is minus the acceleration of the bottom pulley.
My impression is that the OP has been instructed to use conservation of string length to obtain the result. That suggests to me applying your framework to positions and then differentiating.
Likes Chestermiller
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
