Conservation of Work/Momentum of Puck Sliding Off Plate
In summary, the conversation discusses a physics problem involving a curved plate and a puck. The goal is to determine the height the puck will shoot up from the plate. Energy conservation and conservation of momentum are used to solve the problem, with the key factor being the horizontal kinetic energy of the puck not being converted to gravitational potential energy due to the limited forces of the plate. The summary also confirms that the solution provided in the conversation is correct.
SeventeenForever
I saw this problem from a few years ago here on Physics Forum (https://www.physicsforums.com/threads/work-energy-theorem-problem.823990/) and wanted some clarification. Here is the problem:
A curved plate of mass M is placed on the horizontal, frictionless plane as shown. Small puck of mass m is placed at the end of the plate and given an initial horizontal velocity v. How high the puck will shoot up from the plate? Regard radius of curvature to be much smaller than the jump height and consider that the puck leaves the plate vertically.
K1 + U1 = K2 + U2
mv1 = mv2
K= 0.5mv2
U= mgh
[/B]
Based on reading the previous post over and over again, here is my understanding of the problem.
The puck is initially sliding across the horizontal portion of the plate with a velocity, vo. As it approaches the launch point, some of its kinetic energy is converted to the kinetic energy of the plate. With respect to the ground, the puck still has kinetic energy, since it is on the moving plate. There is also some kinetic energy present that will launch the puck up in the air.
Energy Conservation from Initial to Launch Point: Kpuck, initial = Kpuck+plate together + Kpuck
Only the kinetic energy of the puck alone (Kpuck) gets converted to gravitational potential energy.
Energy Conservation from Launch Point to Max Height: Kpuck = Umax height
Plugging in the terms:
Energy Conservation from Initial to Launch: 0.5mvo2 = 0.5(m+M)v2puck & plate + 0.5mv2puck alone
Energy Conservation from Launch to Max Height: 0.5mv2puck alone = mgh
To find the unknown variable, vpuck&plate, we need to use conservation of momentum. Since momentum is a vector, it is conserved in each direction. In the horizontal plane, the initial momentum of the puck is conserved as the puck and the plate move together just before launch.
mvo = (m+M)vpuck & plate
I can then solve for vpuck & plate in terms of the known variables, m, M, and vo, and plug this into the Energy Conservation from Initial to Launch Point to find vpuck alone. Then I can use the Energy Conservation from Launch Point to Max Height: Kpuck = Umax height to find the max height and solve the problem.
My biggest questions/lack of understanding is why exactly the plate starts moving. The question (as in the other post) makes no mention of friction. The only thing I can think of is the plate starts moving as the puck is ramping up, but I still haven't quite connected all the dots. Knowing which way the plate moves is also important for the Conservation of Momentum.
Also, kinetic energy isn't a vector. Hence, why is the "horizontal" kinetic energy of the puck (just before the launch point, presumably from its position on the plate, which is moving) not converted to gravitational potential energy. Lastly, if the everything is frictionless, why would the puck even move with plate at the launch point?
Thanks for reading!
The force of the puck on the plate is normal to the surface of the plate.
Where that surface is horizontal, the force of m on M will be entirely vertical and there is no change in M's velocity.
Where that surface is not horizontal, there will be a horizontal component to the m on M force. And that component will cause M to accelerate horizontally.
That seems to make sense. The problem as written doesn't focus on the ramping so I neglected that.
Does my work seem correct to you?
Thanks for responding so quickly!
Although energy is not a vector, force, acceleration and velocity are. Increasing GPE requires upward movement. With no initial vertical velocity that will require an upward force.
In the set-up, the plate is simply not able to supply the necessary forces to convert all horizontal KE to vertical KE. Indeed, the conservation of momentum means some KE has to remain in the horizontal motion.
Yes.
Thanks guys! It makes more sense now
Related to Conservation of Work/Momentum of Puck Sliding Off Plate
1. What is the conservation of work/momentum?
The conservation of work/momentum is a fundamental principle in physics which states that the total work or momentum of a system remains constant, unless acted upon by an external force.
2. How does the conservation of work/momentum apply to a puck sliding off a plate?
In the case of a puck sliding off a plate, the conservation of work/momentum means that the total work and momentum of the puck and the plate before the puck slides off must be equal to the total work and momentum of the puck after it slides off.
3. What factors affect the conservation of work/momentum in this scenario?
The conservation of work/momentum in the scenario of a puck sliding off a plate is affected by several factors, including the initial velocity and mass of the puck, the angle and height of the plate, and the presence of any frictional forces.
4. Can the conservation of work/momentum be violated?
No, the conservation of work/momentum is a fundamental law of physics and cannot be violated. However, it may appear to be violated if all external forces acting on the system are not considered.
5. How is the conservation of work/momentum used in real-world applications?
The conservation of work/momentum is used in many real-world applications, such as in sports like hockey and billiards, as well as in engineering and transportation systems to calculate the motion and energy of objects. It is also used in the study of collisions and other interactions between objects.
