Conservations law or equations of motion, and other constrains
In summary, the conservation of energy and momentum in special relativity is represented by the equation ##\partial_{\mu}T^{\mu\nu}=0##, where ##T^{\mu\nu}## is the stress-energy tensor. In the case of a perfect fluid, this equation leads to relativistic equations of continuity and motion. In non-relativistic mechanics, the continuity equation is also called the conservation of mass equation, and the equations of motion are also called the conservation of momentum equation. In general relativity, the divergence of the stress-energy tensor serves as both the continuity equation and the equation of motion. To obtain the correct result for the ADM energy-momentum integral in an asymptotically flat space-time
sergiokapone
302
In the special relativity the conservation of energy and momentum is represented by the equation:
##\partial_{\mu}T^{\mu\nu}=0##, where ##T^{\mu\nu}## - stress-energy tensor.
In the case of perfect fluid ##T^{\mu\nu}=(\rho+p/c^2)u_{\mu}u_{\nu}-pg^{\mu\nu}## this equations leads to relativistic equations of continuity and the relativistic equations of motion for a perfect fluid. Some times this eqn ##\partial_{\mu}T^{\mu\nu}=0## call the conservation law, some times - equatin of motion. Why this duality? In non-relativistic mechanics we even know what is meant by the law of conservation, and what is meant by the equation of motion.
In Newtonian mechanics conservation of energy refers specifically to local conservation of a scalar energy density field. ##T^{\mu\nu}## on the other hand includes much more information because it's a tensor; for example the stress-energy tensor of a perfect fluid codifies not only the energy density of the fluid but also the pressure of the fluid. The conservation equation ##\partial_{\mu}T^{\mu\nu}## is really local conservation of stress-energy-momentum so it results in a variety of dynamical equations for a given matter field. For a perfect fluid it straightforwardly leads to the relativistic continuity and Euler equations whereas for the electromagnetic field it leads to Maxwell's equations (https://www.physicsforums.com/showthread.php?t=733219). By combining ##\partial_{\mu}T^{\mu\nu} = 0## with a given foliation of Minkowski space-time into a one-parameter family of space-like hypersufaces we can also derive global conservation of angular momentum etc.
Likes 1 person
##\nabla_{a}T^{ab} = -\frac{3}{2}F_{ac}\nabla^{[a}F^{bc]} + F_{c}{}{}^{b}\nabla_{a}F^{ac} =0##
I do not quite understand how you have proved that these terms
##\nabla^{[a}F^{bc]}=0##
##\nabla_{a}F^{ac}=0##
is equal to zero?
(Maxwell's equations in vacuum)
The proof is in section 20.6 of MTW.
Ok, I try to understand. Tnx.
And another strange thing. Eqn ##\partial_{\mu}T^{\mu\nu}=0## is the only four equations. But number of Maxwell's equations in 3D is 12!
Add the equations [itex] \partial^{[\mu}F^{\nu\rho]} = 0 [/itex] which, as explained by MTW, are a byproduct of the final result, and you'll have all of them.
##\partial_{\mu}T^{\mu\nu}=0## directly implies ##\partial_{\mu}F^{\mu\nu} = 0## so we still end up with 4 equations. ##\partial_{[\gamma}F_{\mu\nu]} = 0## is trivially implied by ##F_{\mu\nu} = 2\partial_{[\mu}A_{\nu]}## where ##A_{\mu}## is the 4-potential so it's not really a consequence of ##\partial_{\mu}T^{\mu\nu}=0##.
*dexter beat me to it! :)
In non-relativistic solid and fluid mechanics, the continuity equation is interchangeably called the conservation of mass equation, and the equations of motion are interchangeably called the conservation of momentum equation. So they are called both continuity equations and conservation equations. In relativity, the divergence of the stress energy tensor (or whatever they call it) is the relativistic continuity equation, and it automatically combines the continuity equation (conservation of mass) with the equation of motion (conservation of momentum) into a single equation.
Chet
Ok, thanks for all.
I have another quastion about integral conservation law. In MTW Sec. 20.2 (Formulaes 20.9) said
in full general relativity theory, for any isolated source, when the closed surface of integration is in the asymptotically flat region surrounding the source, and when asymptotically Minkowskian coordinates are used.
Using first formula of 20.9, and following what has been said, for Schwarzschild black hole I get the ##P^{0}=mc^2##, what is reasonable, where ##m## - is mass of BH. But if I decline to use instructions "Minkowskian coordinates" (mean Cartesian) and using flat spherical coordinates, I get negative infinity (calculations was made in Maple 12).
Why condition to using of Minkowskian coordinates are necessary to obtain the correct result?
Is intact here the condition of general covariance?
The ADM energy-momentum integrals are defined with respect to special Euclidean charts for which the metric tensor representation satisfies necessary convergence criteria. See Wald "General Relativity" problem 11.2. See also here: http://homepage.univie.ac.at/piotr.chrusciel/teaching/Energy/Energy.pdf (p.12 in particular)
As a bit of a digression, for stationary asymptotically flat space-times the total energy of the space-time can be most easily calculated from the Komar integral for energy. More precisely, if we have an asymptotically flat space-time (for the rigorous definition of an asymptotically flat space-time see section chapter 11 of Wald) with a time-like killing field ##\xi^{\mu}##, the Komar energy is given by ##E = -\frac{1}{8\pi}\int _{S}\epsilon_{\mu\nu\alpha\beta}\nabla^{\alpha}\xi^{\beta}## where ##S## is a 2-sphere taken at spatial infinity. For Schwarzschild space-time, using spherical coordinates on ##S##, a very simple calculation yields ##E = M## where ##M## is the Schwarzschild mass parameter.
Thanks for the references.
It's a pity I'm not familiar with the Komar integral's, so I now difficult to understand their physical meaning.
Section 11.2 of Wald is an excellent place to start if you want to grasp their physical meaning. I made a thread regarding a calculation from this section a few months back and in the first paragraph of the thread summarized the motivation behind the Komar energy so if you don't have access to Wald you can take a quick scan of the thread: https://www.physicsforums.com/showthread.php?t=688422
There are also tons of references online regarding both ADM energy-momentum and Komar integrals.
An absolutely excellent reference is the following: http://relativity.livingreviews.org/open?pubNo=lrr-2004-4&page=articlesu4.html and it also addresses your previous question.
Clarify the issue. Condition asymptotically flat metric to calculate the mass, I understand. I just do not understand why you want to use is not arbitrary coordinates, for example, spherical (##ds^2=c^2dt^2-dr^2-r^2d\Omega^2##) or cylindrical, but only Cartesian ##ds^2=c^2dt^2-dx^2-dy^2-dz^2##?
Oh! I find my quastion in your reference http://homepage.univie.ac.at/piotr.chrusciel/teaching/Energy/Energy.pdf
page 6 (above formula 1.1.14 )
More precisely, one finds a mass m in the coordinate system in which g takes the form (1.1.13). This raises immediately the question, whether the number so obtained does, or does not, depend upon the coordinate system chosen to calculate it. We will shortly see that m is coordinate-independent, and indeed a geometric invariant.
(my bold emphasis)
I finds a mass m in the coordinate system in which g takes the form ##g_{\mu\nu}=(1+2\phi)\delta_{\mu\nu}##. Obviously it asymptotically flat and Cartesian.
But, if I try tu use spherical coordinates, ##g_{\theta\theta} = r^2##, for example, increases with increasing distance, I get infinity.
It is indeed coordinate independent but the actual computation of the ADM energy, under its normal definition, requires one to use asymptotically Cartesian coordinates. What you actually did above in post #15 is rewrite the Schwarzschild metric in isotropic form (spatially conformally flat form: http://en.wikipedia.org/wiki/Schwar...c.29_formulations_of_the_Schwarzschild_metric), whose spatial part is clearly asymptotically Cartesian as ##r\rightarrow \infty##. So we can easily evaluate the ADM energy for Schwarzschild space-time if we use isotropic coordinates, again because the spatial part of the metric in said coordinates is manifestly asymptotically Cartesian.
Why do we care if it's asymptotically Cartesian, regardless of the fact that the ADM energy is coordinate-independent? Well take a look at how MTW goes from (20.6) to (20.7). What key equation do they use for ##g_{\mu\nu}## in relation to the asymptotic behavior of the gravitational field of a self-gravitating isolated source?
Yes, that's interesting.
You mean ##g_{\mu\nu}=\eta_{\mu\nu}+h_{\mu\nu}##?
Yes. So they already make use of an asymptotically Minkowskian representation of the metric tensor far away from the isolated source when deriving (20.7) so you can't evaluate (20.7) in a non-asymptotically Minkowskian coordinate system!
Yes, but if I will use the equation (20.6) directly (with Schwarzschild ##g_{\mu\nu}##'s, or Kruskal-Szekeres), what I will get? Mass or dummy number?
You can't do that because ##H^{\mu\nu\alpha\beta}## is itself defined in terms of the asymptotic gravitational field with space-time geometry ##g_{\mu\nu} = \eta_{\mu\nu} + h_{\mu\nu}## far away from the isolated source (c.f. expression 20.3) so it assumes an asymptotically Minkowskian coordinate system.
You can't use the ADM energy-momentum expressions (20.6) if you aren't in an asymptotically Minkowskian coordinate system. See, for example, problem 3 of the following problem set: http://phys.columbia.edu/~nicolis/HW1_solutions.pdf
If you want to explicitly calculate the energy of Schwarzschild space-time in an arbitrary coordinate system then use the Komar integral for energy. If you want I can show you the explicit calculation of the Komar energy in the regular Schwarzschild coordinates.
Yes, of course. It would be great.
Sorry for the delay! I got distracted by a video game :p
So recall that the definition of the Komar energy is ##E = -\frac{1}{8\pi}\int _{S}\epsilon_{\mu\nu\alpha\beta}\nabla^{\alpha}\xi^{\beta}## where ##S## is a 2-sphere taken at spatial infinity and ##\epsilon_{\mu\nu\alpha\beta}## is the volume element on Schwarzschild space-time.
Now in Schwarzschild coordinates we have ##\xi^{\mu} = \delta^{\mu}_t## so the following two results obtain:
##\nabla^{\alpha}\xi^{\beta} = g^{\alpha\gamma}\nabla_{\gamma}\delta^{\beta}_{t} \\= g^{\alpha \gamma}\Gamma ^{\beta}_{\gamma t} \\= g^{r r}\Gamma ^{t}_{r t}\delta^{\alpha}_{r}\delta^{\beta}_{t} + g^{t t}\Gamma ^{r}_{t t}\delta^{\alpha}_{t}\delta^{\beta}_{r} ##
##\epsilon_{\mu\nu\alpha\beta}\nabla^{\alpha}\xi^{\beta} \\= \epsilon_{\mu\nu tr}\nabla^{t}\xi^{r} + \epsilon_{\mu\nu rt}\nabla^{r}\xi^{t} \\= 2\epsilon_{\theta\phi tr}\nabla^{t}\xi^{r} = 2r^2 \sin\theta \nabla^{t}\xi^{r}d\theta d\phi##
where I have used the antisymmetry of ##\epsilon_{\mu\nu\alpha\beta}## and ##\nabla^{\alpha}\xi^{\beta}## (recall that a Killing field satisfies ##\nabla^{\alpha}\xi^{\beta} = -\nabla^{\beta}\xi^{\alpha}##).
Next, ##\Gamma ^{r}_{t t} = -\frac{1}{2}g^{r \mu}\partial_{\mu}g_{tt} = (1 - \frac{2M}{r}) \frac{M}{r^2}## so using our expression for ##\nabla^{\alpha}\xi^{\beta}## above, we have ##\nabla^t \xi^r = -\frac{M}{r^2}##.
So finally ##E = \frac{M}{4\pi}\int _{S}\sin\theta d\theta d\phi = \frac{M}{4\pi}\int _{0}^{2\pi}\int _{0}^{\pi}\sin\theta d\theta d\phi = M##.
EDIT: And make sure you take a look at the explicit calculation of the ADM energy of Schwarzschild space-time given in the link in post #20. It shows how to go from the regular Schwarzschild coordinate system to a coordinate system that is manifestly asymptotically Minkowskian, and subsequently calculates the ADM energy in this asymptotically Minkowskian coordinate system.
FAQ: Conservations law or equations of motion, and other constrains
What is the conservation of energy?
The conservation of energy is a fundamental principle in physics that states that energy cannot be created or destroyed, it can only be transferred or transformed from one form to another. This means that the total amount of energy in a closed system will remain constant over time.
What are the equations of motion?
The equations of motion, also known as Newton's laws of motion, describe the relationship between an object's mass, acceleration, and the forces acting upon it. They are: 1) The law of inertia, 2) The relationship between force, mass, and acceleration, and 3) The principle of action and reaction.
How do conservation laws apply to real-world situations?
Conservation laws apply to real-world situations by providing a framework for understanding and predicting the behavior of physical systems. For example, the conservation of momentum can be used to analyze collisions or the conservation of energy can be applied to calculate the efficiency of machines.
What are constraints in physics?
In physics, constraints refer to any conditions or limitations that restrict the motion or behavior of a physical system. These can include external forces, such as friction or gravity, or internal factors, such as the shape or structure of an object.
How do constraints affect the equations of motion?
Constraints can affect the equations of motion by adding additional terms or modifying existing equations. For example, in a system with friction, the equations of motion would include a term for the frictional force. Constraints can also limit the range of motion or alter the acceleration of an object, which would be reflected in the equations of motion.
