fog37
- 1,568
- 108
Hello,
I would like to review and validate some concepts that I have been recently thinking about. Hope this is correct and useful to others that need to refresh these concepts.
Here a simple made up problem: a small satellite (weight ##980 N##) is pushed vertically upward a distance of ##6 m## by a thrust force ##F## of magnitude ##2000 N##. The thrust does positive work ##(2000)(6)=12000 J## while gravity does negative work ##(-980)(6)= 5880 J##.
The net work is positive and equal to ##(12000-5880)= 6120 J## and the satellite's kinetic energy increases by that amount.
The thrust force seems responsible for making the satellite gain gravitational potential energy ##PE## by bringing to an altitude of ##6m##. Why can a nonconservative force not change the ##PE## of the satellite? I know ##PE## is not defined for nonconservative forces. If it is not defined, it means that nonconservative forces, like the thrust, cannot increase/decrease ##PE##.
Maybe the correct way to think about it is the following: the thrust force will simply not affect or change the system's potential energy. Although the thrust is a force that brings the satellite to a new position changing the configurational state of the satellite-Earth system, it is not having any role in the potential energy of the system. All we say is that the thrust does positive work which would produce a ##12000K## increase in ##KE## of the satellite. But the conservative gravitational force, as the satellite climbs up, does negative work on the satellite reducing its kinetic energy by ##5880J##. The ##5880 J## are not lost but simply converted from kinetic energy into gravitational potential energy. A dissipative force always does negative work and always reduces the kinetic energy converting it into a different form of energy (thermal energy instead of potential energy) and transfer it to a different body (the entity that produces the dissipative force itself).
Thanks!
- Forces can be classified as either conservative or nonconservative. Dissipative forces are always nonconservative forces but not all nonconservative forces are dissipative. For example, the thrust of a rocket is a nonconservative force but not a dissipative force.
- The total work done on a system is the sum of the works done by each force acting on the system: ##W_{total}=W_{conservative}+W_{nonconservative}=\Delta KE##.
- The change in the "mechanical" energy of the system, defined as ##E_{mech}=KE+PE##, is equal to the work done by nonconservative forces: ##W_{nonconservative}=\Delta E_{mech}##. The net work ##W_{conservative} ## done by all the conservative forces never changes the total mechanical energy of the system.
- Once we define the system and its surrounding (everything outside of the system), some of the forces which are external to the system can be conservative and some can be nonconservative. The net force is vector sum of all the conservative and nonconservative forces and is nonconservative if nonzero (adding a conservative force to a nonconservative force produces a nonconservative force).
- If the net external force was either zero or nonzero but conservative, the total "mechanical" energy of the system would remain constant. The total energy of the system (mechanical energy + all other energy forms) is constant only if the net external force is zero.
Thanks!
