Is there any way to prove that a given force is conservative?
  • Thread starter alphabeta1720
  • Tags
    Force
In summary, a force is conservative if its curl is zero or if the net work done is zero when moving a particle in a closed path. This can be mathematically proven using the del and curl operators, where the force is conservative if the curl of its vector derivative is zero. The condition for a force to be conservative is that its mixed derivatives are equal. Using this, we can determine whether a given force is conservative or not.
alphabeta1720
Yes, a force is conservative if the curl is zero.
Or, equivalently, the net work done is zero if you move a particle in a path that starts and ends in the same place.
Mathematically a vector is said to be conservative if it is the gradient of a potential
This means that for the space considered there must be a potential at every point ( can be zero ) and the work done from moving from one point to another depends only on the difference between the potentials at these two points. So the path has no say
If you want to know if a force is conservative, and if you have the equation for the force ( in terms of catesian or polar co ordinates ) then you have use the mathematical curl operation (del cross f) where del is the vector derivative with respect to space. If the force f is conservative this term will be zero.
The reason for that is that a gradient can be represented as (del V ) where V is a scalar potential.
Then the curl operation becomes ( del cross del V ) since these 2 vectors point in the same direction the cross product has to be zero.
more on del operator
http://hyperphysics.phy-astr.gsu.edu/hbase/vecal.html
i'm not sure from your question, but you can prove this by analyzing a few simple/isolated systems such as an object hung to a string on a frictionless surface, a simple pendulum, and many others examples, those are simple, and you can further study about the conservation of energy for more understanding.
Thank you for that
but can anyone help me solving these problems (Sorry, but I don't know about 'curl' and 'del' operators)
Q1 Consider the two dimensional force F = f(x,y) i + g(x,y) j . Is it possible to determine whether this is a conservative force without any additional information? What if f(x,y) = f(x)
and g(x,y) = g(y)
Q2 which of the following forces is conservative?
A) F = y i - x j B) F = xy i - xy j
C) F = y i + x j D) F = xy i + xy j
E) F = 3x i + 4y j
(There may be more than 2 correct answers)
Thank You
alphabeta1720 said:
Thank you for that
and g(x,y) = g(y)
Yes, there is. The work done in moving an object using that force along a path in the plane by [itex]\int_p \vec{F}\cdot d\vec{s}= \int_p f(x,y)dx+ g(x,y) dy[/itex] depends only on the beging and ending points and is independent of the specific path. Once can show that that is true if and only if there exist some "potential function" G(x,y) (numerical valued, not vector valued) such that [itex]\nabla G= \vec{F}[/itex] which just means that
[tex]f(x,y)= \frac{\partial G}{\partial x}[/tex]
and
[tex]g(x,y)= \frac{\partial G}{\partial y}[/tex]
Assuming there is such a function G, then
[tex]\frac{\partial^2 G}{\partial y\partial x}= \frac{\partial f(x,y)}{\partial y}[/tex]
and
[tex]\frac{\partial^2 G}{\partial x\partial y}= \frac{\partial g(x,y)}{\partial x}[/tex]
Since, as long as the derivatives are continuous, the "mixed derivatives" are continuous, we can say that a force, [itex]\vec{F}= f(x,y)\vec{i}+ g(x,y)\vec{j}[/itex] is "conservative" if and only if it satifies the "cross condition"
[tex]\frac{\partial f}{\partial y}= \frac{\partial g}{\partial x}[/tex]
E) F = 3x i + 4y j
Thank You
Apply the condition
to each of those.
(I can't help but think that if you are asked a question like this, you are expected to have learned all this before!)
OK! next I am going to do is to learn about them
FAQ: Is there any way to prove that a given force is conservative?
1. What is a conservative force?
A conservative force is a force that conserves mechanical energy. This means that the work done by the force is independent of the path taken by the object. In other words, the work done by a conservative force only depends on the initial and final positions of the object, not on how the object got from one position to the other.
2. How can you prove that a given force is conservative?
One way to prove that a force is conservative is to show that the work done by the force along a closed loop is zero. This means that the object returns to its initial position and has the same amount of energy as it did before. If the work done by the force is not zero, then the force is not conservative.
3. Can a non-conservative force become conservative?
No, a non-conservative force cannot become conservative. A force is either conservative or non-conservative and cannot change its nature. For example, friction is a non-conservative force and will always dissipate energy, it cannot suddenly become a conservative force.
4. Are all fundamental forces in nature considered conservative?
No, not all fundamental forces in nature are considered conservative. The four fundamental forces are gravity, electromagnetism, weak nuclear force, and strong nuclear force. Of these, only gravity and electromagnetism are considered conservative forces.
5. How does the concept of potential energy relate to conservative forces?
Conservative forces are closely related to the concept of potential energy. A conservative force can be defined as the negative gradient of a potential energy function. This means that the work done by the force can be calculated by taking the difference in potential energy between the initial and final positions of an object. In other words, conservative forces can store potential energy, which can be converted into kinetic energy as the object moves.
