Conservative Nature of Electric forces
In summary, the conversation is discussing the concept of conservative forces in electrostatics. It is mentioned that a force exerted by a static charge distribution is considered conservative, but the question arises if this still holds true when the force is used to accelerate a charged particle. The individuals in the conversation also discuss the relationship between energy conservation and conservative forces, and how it applies to the movement of a particle. The conversation concludes with a discussion on the definition of a conservative force and its mathematical equivalent properties.
SpartanG345
70
My textbook says for every electric field due to a static charge distribution, the force exerted by that field is conservative.
If that force is used to accelerate a charged particle, wouldn't the particle disapate some of its energy, as EMR? therefore you cannot say U_a + K_a = U_b + K_b as some of the particles energy would have gone
can anyone explain what that above statement means with respect to the motion of the particle?
thankyou :)
thankyou :)
I've highlighted the key word in your textbook's statement...In electrostatics charges don't radiate.
i understand that, the charge distribution is static, but there was a question, where a charge is accelerated by a static charge distribution.
Say a charge is being accelerated by a static charge distribution, wouldn't that charge lose some energy?
such that is incorrect to say Ua + Ka = Ub + Kb, since the charge accelerates
Sure, the accelerating charge will radiate some energy away. However, this is unimportant. Energy conservation and conservative forces are not the same thing. What is the actual definition of a conservative force?
A conservative force is a force that conserves energy, such that the work done by a conservative force can be released and is reversible.
So i suppose as the electron moves away some of its kinetic energy is dissipated as EMR but its Kinetic energy is also turned into potential energy which can be recovered.
But it is still wrong to say, Ua + Ka = Ub + kb as some energy is lost in the movement from a to b, i think the question assumes that this loss is negligible don't you think?
That's a somewhat inaccurate definition.
This is a much better definition...From this definition, you can say 3 mathematically equivalent things:
(1)The work done by the force over any simple, closed path is zero (otherwise it would be an irreversible process)
[tex]W=\oint\textbf{F}\cdot d\textbf{r}=0[/tex]
(2)The curl of [itex]\textbf{F}[/itex] must vanish (you can derive this easily using Stokes's Theorem and property 1)
[tex]\mathbf{\nabla}\times{\textbf{F}}=0[/tex]
(3)The force can be written as the (negative by convention) gradient of a single-valued, contiuous potential function
[tex]\textbf{F}=-\mathbf{\nabla}U[/tex]Now, surely any electrostatic force satisfies property 2 (and hence the other two properties as well), right?
Related to Conservative Nature of Electric forces
1. What does it mean for electric forces to be conservative?
Being conservative means that the work done by or against an electric force is independent of the path taken. This means that the amount of energy required to move a charge from one point to another is the same regardless of the path taken.
2. How does the conservative nature of electric forces affect the behavior of charges?
The conservative nature of electric forces means that charges will always move in a way that minimizes their potential energy. This results in charges moving towards areas of lower potential energy, which can lead to the formation of stable equilibrium points.
3. What is the relationship between conservative electric forces and electric potential?
The conservative nature of electric forces is directly related to electric potential. Electric potential is a measure of the work done per unit charge in moving a charge from one point to another. Since conservative forces result in the same amount of work regardless of the path taken, the electric potential is also independent of path.
4. How does the concept of energy conservation apply to conservative electric forces?
The principle of energy conservation states that energy cannot be created or destroyed, only transferred from one form to another. In the case of conservative electric forces, the total energy of a system (kinetic energy + potential energy) will remain constant regardless of any changes in position or velocity of the charges involved.
5. What are some real-life examples of conservative electric forces?
Some real-life examples of conservative electric forces include the motion of electrons in a circuit, the motion of charged particles in Earth's gravitational field, and the behavior of electric dipoles in a dielectric material.
