Consider the Electric Field E(t,x,y,z) = Acos(ky-wt)k
The discussion revolves around calculating the magnetic field from the given electric field E(t,x,y,z) = A cos(ky-wt) k, specifically addressing two parts of a homework problem. For part a, participants are trying to find the magnetic field using the relationship ∂B/∂t = -∇×E, with some confusion about the direction of the curl and how to derive B. In part b, they confirm that the divergence of E is zero, but there is uncertainty about the calculations leading to this conclusion and how to show that ∇·B = 0. Clarifications on the definitions of curl and divergence are provided, helping participants understand the vector components involved. Overall, the conversation highlights the challenges in applying vector calculus to electromagnetic fields.
Smazmbazm
Consider the Electric Field E(t,x,y,z) = A\cos(ky-wt)\hat{k}
a) Find the magnetic field such that \partial_t B + \nabla \times E = 0
b) Show that ##\nabla \cdot E = 0## and that ##\nabla \cdot B = 0##.
So for part a, the curl of E = -\partial B / \partial t
Curl of E works out to be -Ak\sin(ky-wt) I think but then I'm not sure how you get the magnetic field.
For part b, div E = 0. I don't understand how to get this. I do the calculations and get -A*t*\sin(k*y - t*w) - A*y*\sin(k*y - t*w)? Where am I going wrong? I don't know how to do the second part at all, div B = 0.
Thanks in advanced
Smazmbazm said:
Consider the Electric Field E(t,x,y,z) = Acos(ky-wt)\hat{k}
a) Find the magnetic field such that \partial t B + \nabla \times E = 0
b) Show that \nabla \cdot E = 0 and that \nabla \cdot B = 0.
Curl of E works out to be -Aksin(ky-wt) I think but then I'm not sure how you get the magnetic field.
The curl of a vector field is a vector field. What is the direction vector?
Find B by solving the equation you are given:
\nabla\times \vec{E}= -\frac{\partial\vec{B}}{\partial t}
For part b, div E = 0. I don't understand how to get this. I do the calculations and get -A*t*sin(k*y - t*w) - A*y*sin(k*y - t*w)? Where am I going wrong? I don't know how to do the second part at all, div B = 0.
div fi+ gj+ hk is f_x+ g_y+ h_z. n Here f and g are 0 while h is a function only of y and t, not z.
Thanks in advanced
Hi Smazmbazm! :smile:
(i assume k is the unit vector in the z direction)
in which direction? :wink:
i'm not sure how you got that :confused:
div is simply ∂/∂x of the x coordinate + … + …
try again :smile:
Right so for the first part \nabla \times E = [\partial / \partial y Acos(ky - wt) - 0]\hat{i} + [\partial / \partial x Acos(ky - wt) - 0]\hat{j} + [0 - 0]\hat{k}.
\nabla \times E = -Aksin(ky - wt)\hat{i}, correct?
For b, right. I think I confused myself. The definition of div is \partial f / \partial x + \partial g / \partial y + \partial h / \partial z. Is that f, g and h referring to each direction? Like \hat{i}, \hat{j}, \hat{k}? If so, that makes more sense
Thanks guys
correct :smile:
yup, that's div(f,g,h) :smile:
Sorry the previous post should be \partial B / \partial t = -Aksin(ky - wt)\hat{i} rather then \<br /> \nabla \times E = -Aksin(ky - wt)\hat{i}
So to get the electric field you integrate -Aksin(ky - wt) with respect to t? Not sure where to go from there..
Now I'm getting confused …
isn't it the magnetic field that you want? :confused:
Yes, integrate ∂B/∂t wrt t, and you get B. :smile:
Yes, sorry, magnetic not electric. Ok, thanks tiny-tim
  • · Replies 0 ·
