Consideration of number of significant figures in experimental quantities
f3sicA_A
I measure time accurate to the sixth decimal place using a Photogate (seventh digit is the uncertain digit). How many decimal places should I round of this time value (and why?) given that I also measure length with an uncertainty of ##\pm0.1## (cm), and I want to use the two experimental quantities to calculate velocity of an object? To calculate uncertainty in the final velocity that I calculate, I use summation in quadrature.
$$d=s\times t$$
$$\frac{\delta a}{a}=\sqrt{\left(\frac{\delta b}{b}\right)^2+\left(\frac{\delta c}{c}\right)^2}$$
I am not sure how to approach this problem. I know that there really is no use taking time values accurate up to the sixth decimal place if my length values are accurate only to the first decimal place, after all errors should be comparable. So I wanted to know how I should quote my time values up to the appropriate decimal places, and is there a general rule one can follow in such situations?
What's wrong with using $$\frac{\delta d}{d}=\sqrt{\left(\frac{\delta s}{s}\right)^2+\left(\frac{\delta t}{t}\right)^2}~?$$ If ##~\dfrac{\delta s}{s}>>\dfrac{\delta t}{t}##, $$\frac{\delta d}{d}\approx \left(\frac{\delta s}{s}\right)\implies \delta d=(st)\frac{\delta s}{s}=t\delta s.$$
Likes f3sicA_A
I don't see anything wrong with it, but my professor mentions that I need to round of the uncertainty in time to keep consistent with significant figures and decimal places. For instance, let us say I have a length measure of 22.1 cm and a time measure of 0.569824 s (just arbitrary values), then speed calculation as follows:
$$s=\frac{22.1}{0.569824}$$
This seems to me like an absurd way of dealing with significant figures/decimal places?
As an exercise, calculate the total error if the time is rounded to .570, .5698, .56982 and .569824
Note: since you are rounding, the error for each of these numbers is different.
It may look a little strange but IMO it's OK. If ##t=0.569824 s##, then I’d say that’s what you should record and use. Presumably the associated uncertainty is 0.000001s.
The symbol ‘s’ is sometimes used for displacement so let’s avoid any confusion and use ##x## for distance and ##v## for speed.
In this case ##v = \frac {22.1cm}{0.569824 s} = 38.7839cm/s##, which now needs rounding.
As already noted, the fractional uncertainty in ##t## is negligible compared to the fractional uncertainty in ##x##. So here we can use:
##\delta v = v \frac {\delta x}{x}= 38.7839 cm/s \times \frac {0.1cm}{22.1cm}##
## = 0.2cm/s## to 1 sig. fig. (or ##0.18cm/s## to 2 sig. figs.)
The value of ##v## should then be rounded to the same number of decimal places as ##\delta v## so we end up with ##v=(38.8 \pm 0.2) cm/s##.
Or if we prefer to use 2 sig. figs. for ##\delta v## we get ##v = (38.78 \pm 0.18) cm/s##.
Note: if we want to use ##v## in subsequent calculations, we should use its unrounded value to avoid introducing unnecessary rounding errors.
First you do the exact calculation $$s=\frac{22.1~\text{cm}}{0.569824~\text{s}}=38.783905205817937~\text{cm/s}.$$I deliberately kept a ridiculous number of significant figures to make a point.
Now for the calculation of the uncertainties. Use exponential notation, one decimal place is sufficient.
##\dfrac{\delta d}{d}=\dfrac{0.1}{22.1}=4.5\times 10^{-3} \implies \left(\dfrac{\delta d}{d} \right)^2=2.0\times 10^{-5}##
##\dfrac{\delta t}{t}=\dfrac{0.1}{22.1}=8.8\times 10^{-6}\implies \left(\dfrac{\delta t}{t} \right)^2=7.7\times 10^{-11}##
##\left(\dfrac{\delta d}{d} \right)^2+\left(\dfrac{\delta t}{t} \right)^2=2.0\times 10^{-5}.## The fractional uncertainty in time doesn't contribute anything and can be ignored.
Then $$\delta s=s*\sqrt{\left(\dfrac{\delta d}{d} \right)^2}=38.783905205817937~(\text{cm/s})\times 4.5\times 10^{-3}=2.8\times 10^{-2}~\text{cm/s}.$$ How to report the value of ##s##? Note that the uncertainties in exponential form were carried to two decimal places to avoid too much roundoff. At this point you round the uncertainty to one sig-fig: ##\delta s = 0.03~\text{cm/s}.## That's two decimal places. Your reported value for ##s## is truncated accordingly to two decimal places, $$s=38.78\pm 0.03 ~\text{cm/s}.$$
I do not understand. The equation you quote does not seem to be an example of rounding the time to be consistent with the distance accuracy. That would look like $$s=\frac{22.1}{0.570}$$
FAQ: Consideration of number of significant figures in experimental quantities
What are significant figures in experimental quantities?
Significant figures are the digits in a number that carry meaningful information about its precision. This includes all non-zero digits, any zeros between significant digits, and any trailing zeros in a decimal number.
Why is it important to consider significant figures in experimental data?
Considering significant figures is crucial because it reflects the precision of the measurements and the limitations of the measuring instruments. It prevents the overstatement of the accuracy of results and ensures that calculations and conclusions are scientifically valid.
How do you determine the number of significant figures to use in calculations?
The number of significant figures in the result of a calculation should be based on the measurement with the least number of significant figures used in the calculation. For addition and subtraction, the result should have the same number of decimal places as the measurement with the fewest decimal places.
What are the rules for rounding significant figures?
When rounding to a certain number of significant figures, if the digit immediately after the last significant figure is greater than or equal to 5, you round up the last significant figure. If it is less than 5, you leave the last significant figure as it is. For example, rounding 3.456 to three significant figures would give 3.46.
How do you handle significant figures in multiplication and division?
In multiplication and division, the number of significant figures in the result should match the number in the least precise measurement used in the calculation. For example, if you multiply 2.34 (3 significant figures) by 1.2 (2 significant figures), the result should be reported with 2 significant figures, as 2.8.
