Considering the criterion for limit proofs
In summary: Therefore, by definition of a limit, we can conclude that $\lim_{x \to a} |f(x)| = |L|$. In summary, the given statement is true and can be proven by assuming there exists a $\delta$ that satisfies the condition $||f(x)|-|L||<\varepsilon$ for $0<|x-a|<\delta$. The objective is to show that $\lim_{x\to a} |f(x)| = |L|$, and we can do this by finding a $\delta$ or by proving that the statement is true assuming there will be a $\delta$.
Amad27
412
In a proof.
Prove that **given**:
$$\lim_{x \to a} f(x) = L$$ then
$$\lim_{x\to a} |f(x)| = |L|$$
We know that
$$|f(x) - L| < \epsilon \space \text{for} \space |x - a| < \delta_1$$
What is the objective then?
Do we prove there exists a $\delta_2$ such that $\displaystyle \lim_{x\to a} |f(x)| = |L|$
Or do we go from the fact that**it is true that:** $|f(x) - L| < \epsilon \space \text{for} \space |x - a| < \delta_1$ and then somehow using $\delta_1$ derive that:
$| |f(x)| - |L| | < \epsilon$
Or do we find a $\delta$?We can easily state:
$$\left| |f(x) - |L| \right| \le \left| f(x) - L \right| < \epsilon$$
But we did not find the $\delta$?
Bottomline: So what is the point? Finding $\delta$ or just proving it is $< \epsilon$ assuming there will be a $\delta$ so that the statement will be true?
Thanks!
It's not necessary to work with another $\delta_2>0$. So yes, you just assume there will be a $\delta$ so that the statement will be true.
Proof
Let $\varepsilon>0$, since $\lim_{x \to a} f(x)=L$ there exists a $\delta>0$ such that $||f(x)|-|L||\leq |f(x)-L|<\epsilon$ if $0<|x-a|<\delta$.
Conclusion: we have found for every $\varepsilon>0$ a $\delta>0$ such that $||f(x)|-|L||<\varepsilon$ if $0<|x-a|<\delta$.
FAQ: Considering the criterion for limit proofs
What is a limit proof?
A limit proof is a mathematical method used to show that the values of a function approach a specific value (known as the limit) as the input values get closer and closer to a certain point.
Why is it important to consider the criterion for limit proofs?
The criterion for limit proofs helps determine whether a function has a well-defined limit at a given point. This is crucial for understanding the behavior of functions and making accurate calculations in mathematics and science.
What is the main criterion for limit proofs?
The main criterion for limit proofs is the epsilon-delta definition, which states that for a given small value (epsilon), there exists a corresponding input value (delta) that ensures the difference between the output value and the limit value is smaller than epsilon.
How is the criterion for limit proofs used in real-life applications?
The criterion for limit proofs is used in various fields, such as physics, engineering, and economics, to model and predict real-life phenomena. It is also used in computer science for numerical analysis and optimization algorithms.
What are some common mistakes to avoid when using the criterion for limit proofs?
Some common mistakes to avoid when using the criterion for limit proofs include overlooking the order of operations, not considering the domain of the function, and using incorrect notation. It is also important to carefully choose the epsilon and delta values to ensure the proof is valid.
