- #36
DrChinese
- 1,971
OK, I'm going to accept this as I promised. There's no issue with the math. I would refer to this as the first half of the EPR logic (modified for spin/polarization). Basically, we make the eminently reasonable deduction that there must be an "element of reality" associated with a 100% certain outcome when an undisturbed system has interacted with another system in the past. This deduction rests on the assumption that the existence of the element of reality preceded the measurement. Of course you use the same assumption as a definition: "...a realistic measurement, we can construct histories...". So that construction defines the realism we seek to discuss. That's fair, in fact that's one of the points of CH. But that assumption is of course fair game for experimental disproof.Morbert said:@DrChinese So let's now compute this probability using the CH formalism. First, we construct a set of consistent histories ##\{C_\omega\}##, where$$C_\omega = \left[\Psi_0\right]\odot\left[\omega\right]\odot\left[00\lor11\right]$$Computing the same probability ##\mathrm{Pr}(00 \lor 11 | \omega)##
\begin{eqnarray*}\mathrm{Pr}(\omega) &=& \mathrm{tr} C_\omega \left[\Psi_0\right]C_\omega^\dagger&=& |c_\omega|^2\\\mathrm{Pr}(\left[11\lor 00\right]\land\omega) &=& \mathrm{tr} C_\omega \left[\Psi_0\right]C_\omega^\dagger&=& |c_\omega|^2\\
\mathrm{Pr}(00 \lor 11 | \omega)&=&\frac{\mathrm{Pr}(\left[11\lor 00\right]\land\omega) }{\mathrm{Pr}(\omega) }&=& 1\end{eqnarray*}Alternatively, if we want to describe a realistic measurement, we can construct histories ##\{C_{\omega,\uparrow_\omega},C_{\omega,\downarrow_\omega}\}## where \begin{eqnarray*}C_{\omega,\uparrow_\omega}&=& \left[\Psi_0\right]\odot\left[\uparrow_\omega\uparrow_\omega\right]\odot\left[\omega\right]\odot\left[11\right]\\C_{\omega,\downarrow_\omega}&=& \left[\Psi_0\right]\odot\left[\downarrow_\omega\downarrow_\omega\right]\odot\left[\omega\right]\odot\left[00\right]\end{eqnarray*}We can use the coarse-graining ##C_\omega = C_{\omega,\uparrow}+C_{\omega,\downarrow}## to compute the probabilities above, but now we can also determine if a realistic measurement occurs. Griffiths et al identify a measurement with the conditions \begin{eqnarray*}\mathrm{Pr}(\omega\land\uparrow\uparrow) &=& \mathrm{Pr}(\omega\land11) &=& \mathrm{Pr}(\omega\land\uparrow\uparrow\land11)\\\mathrm{Pr}(\omega\land\downarrow\downarrow) &=& \mathrm{Pr}(\omega\land00) &=& \mathrm{Pr}(\omega\land\downarrow\downarrow\land11)\end{eqnarray*}These conditions hold in this case, so we can use this set of histories to describe the realistic scenario where a measurement reveals a pre-existing property.
So let's start with the EPR elements of reality being equivalent to the CH realistic measurement. This applies very nicely to the initial thoughts we might have regarding normal PDC entangled pair production. I won't bring Bell into the discussion, so we can skip any debate about whether Bell's Theorem/Inequality applies.
So your next step should be to apply your well-presented explanation of PDC pair production to pair production by swapping. Ideally, you would initially tackle one of the following scenarios (both require explanation, of course):
a) The Ma paper, where the entanglement is created unambiguously (all reference frames) in the future of the entangled 1&4 pair. Obviously, the challenge here is to explain how your equations {Pr(ω∧↑↑)=Pr(ω∧11), Pr(ω∧↓↓)=Pr(ω∧00)} - which assume the ↑↑/↓↓ occurs before the 11/00 - works when the measurements occur before there exists any entangled relationship whatsoever between the 2 photons (1 & 4).
After all, your math in #33 assumed State(ω∧↑↑) -> Pr(ω∧11), State(ω∧↓↓) -> Pr(ω∧00). That relationship is by delayed choice in this case, so the states leading to the certain outcome don't yet exist.
b) The Sun paper, where the measurements occur distant to each other, and the 1 & 4 photons never coexist in any common backward light cone. Presumably, 2 such photons could have never been placed in an entangled state in the past (that being ruled out experimentally) if Einstein locality holds.
After all, how could we ever get to State(ω∧↑↑) or State(ω∧↓↓) if they didn't first interact? Which they are not allowed to do in the experiment, having been created by distant (25 km apart) sources.
BTW: Thanks for your time working on this with me.-DrC
