Constant Acceleration -- Equation for Vavge
In summary: I had a brain lapse and was trying to solve it algebraically without using the given formulas. I see now that it's quite simple.In summary, we are given the equation Vav = (x-x0)/t and encounter a second expression for Vav that is valid for constant acceleration, where the average velocity during any time interval is simply the arithmetic average of the velocities at the beginning and end of the interval. This can be proven graphically or algebraically using the equations of uniform acceleration.
Danger Mouse
I've recently started Sears and Zemansky's "University Physics"... Everything was fine until pg. 42.
Initially we are given the statement Vav = (x-x0)/t, so far so good. But, we encounter the following paragraph...
"We can also get a second expression for Vav that is valid only when the acceleration is constant, so that the v-t graph is a straight line (as in Fig 2-14 - [I've omitted the graph here, it's a v-t graph with constant acceleration]) and the velocity changes at a constant rate. In this case the average velocity during any time interval is imply the arithmetic average of the velocities at the beginning and end of the interval."
For the time interval from 0 to t:
Vav = (v0 + v)/2
I can't for the life of me figure out where the above equation comes from.
My Apologies if homework is the wrong place for this.
How would you calculate an arithmetic average of two numbers, let's say 10 and 20?
Danger Mouse said:
Homework Statement:: I've recently started Sears and Zemansky's "University Physics"... Everything was fine until pg. 42.
Homework Equations:: ...
Vav = (v0 + v)/2
The easiest way to see it is graphically. Draw a graph of velocity against time. It will be a straight line from height v0 to height v1. The average height is (v0 + v1)/2.
(The distance covered is the area underneath.)
They're just giving it to you as an unproven theorem. Even though average velocity is emphatically NOT defined as the average of the start and end velocities in general, in the case of uniform acceleration they are the same.
You can prove it graphically as another answer suggests. You can also derive it algebraically from the equations of uniform acceleration.
##v = v_0 + at \Rightarrow at = v - v_0##
##d = v_0t + (1/2)at^2##
So ##v_{avg} = d/t = v_0 + (1/2)at = v_0 + (1/2)(v - v_0) = (1/2)(v + v_0)##
Likes gmax137
These expressions are equivalent. Perhaps it will help you to see how.
Recall that:
##a=constant \implies v(t)=at+v_0 \implies x(t) = \frac{at^2}{2} + v_0t + x_0 \tag{1}##
Now the first expression for the average velocity is:
##\frac{x_2-x_1}{t_2-t_1}\tag{2}##
If we use the third expression in (1) for the x values in (2), then this gives:
##\frac{\frac{a t_2^2}{2} + v_0t_2 + x_0 -\left(\frac{a t_1^2}{2} + v_0t_1 + x_0\right)}{t_2-t_1}\tag{3}##
This simplifies to:
##\frac{\frac{a }{2}(t_2^2 - t_1^2) + v_0(t_2-t_1)} {t_2-t_1}\tag{4}##
Now consider the second expression you give for the average velocity:
##\frac{v_1 + v_2}{2}\tag{5}##
If we use the second expression in (1) for the velocity values in (5), then we have:
##\frac{at_1 +v_0+ at_2 + v_0}{2} = \frac{a(t_1 + t_2)+ 2v_0}{2} = \frac{a(t_1 + t_2)+ 2v_0}{2} \cdot \frac{t_2-t_1}{t_2-t_1} = \frac{\frac{a }{2}(t_2^2 - t_1^2) + v_0(t_2-t_1)} {t_2-t_1}\tag{6} ##
So the expressions (4) and (6) are equivalent, and therefore they both represent the average velocity over some time interval given constant acceleration.
HTH
Likes Danger Mouse
Thanks! It does...
Related to Constant Acceleration -- Equation for Vavge
1. What is the equation for average velocity under constant acceleration?
The equation for average velocity (Vavg) under constant acceleration is Vavg = (V0 + V)/2, where V0 is the initial velocity and V is the final velocity.
2. How is average velocity related to acceleration?
Average velocity is directly proportional to acceleration. This means that as acceleration increases, average velocity also increases, and vice versa.
3. Can the equation for average velocity be used for non-uniform acceleration?
No, the equation for average velocity is only valid for constant acceleration. For non-uniform acceleration, the equation for average velocity cannot be used and the instantaneous velocity must be calculated instead.
4. What is the unit of measurement for average velocity?
The unit of measurement for average velocity is meters per second (m/s).
5. How does time affect the value of average velocity?
The value of average velocity is directly proportional to the time interval over which it is measured. This means that as the time interval increases, the average velocity also increases, and vice versa.
