Constant Acceleration involving two identical objects
In summary, the green car has an initial velocity of 41.0 km/h and the red car has an initial velocity of 23.0 km/h. At time t=7.278260871 seconds, the cars pass each other at x=76.6 m.
coco87
a red car and a green car, identical except for the color, move toward each other in adjacent lanes and parallel to an x axis. At time t = 0, the red car is at xr = 0 and the green car is at xg = 250 m. If the red car has a constant velocity of 23.0 km/h, the cars pass each other at x = 46.5 m, and if it has a constant velocity of 41.0 km/h, they pass each other at x = 76.6 m. What are (a) the initial velocity (in km/h) and (b) the acceleration of the green car?
From this I gather the following:
[tex]R_x_0 = 0m[/tex] iff [tex]t=0s[/tex]
[tex]G_x_0 = 250m[/tex] iff [tex]t=0s[/tex]
[tex]R_x = G_x = 46.5m[/tex] iff [tex]R_v = 23 \frac{km}{h} = 6.3889 \frac{m}{s}[/tex]
[tex]R_x = G_x = 76.6m[/tex] iff [tex]R_v = 41 \frac{km}{h} = 11.3889 \frac{m}{s}[/tex]
[tex]R_a = 0 \frac{m}{s^2}[/tex] since the velocity is constant
[tex]T=7.278260871s[/tex] iff [tex]R_v = 6.3889 \frac{m}{s}[/tex]
[tex]T=6.725853664s[/tex] iff [tex]R_v = 11.3889 \frac{m}{s}[/tex]
Since the problem is dealing with constant acceleration, we choose the following formula:
[tex]x-x_0=v_0 t + \frac{1}{2} a t^2[/tex]
and rewrite it such as [tex]x=v_0 t + \frac{1}{2} a t^2 + x_0[/tex]
Well, I converted the velocities above to [tex]\frac{m}{s}[/tex], and obtained the time at both cross points (where [tex]R_x = G_x[/tex]). I also realized that I need to setup both cars into simultaneous equations to solve for the missing variables ([tex]G_v_0[/tex] and [tex]G_a[/tex]). So, I did the following:
R1: [tex]46.5=(6.3889)(7.278260871) + \frac{1}{2} 0 (7.278026081)^2 + 0[/tex]
R1: [tex]\Rightarrow 46.5=(6.3889)(7.278260871)[/tex]
G1: [tex]46.5=V_0(7.278026081)+\frac{1}{2}a(7.278026081)^2+250[/tex]
E1: [tex](6.3889)(7.278260871) =V_0(7.278026081)+\frac{1}{2}a(7.278026081)^2+250[/tex] since both equations are equal.
R2: [tex]76.6=(11.3889)(6.725853664) + \frac{1}{2} 0 (6.725853664)^2 + 0[/tex]
R2: [tex]\Rightarrow 76.6=(11.3889)(6.725853664)[/tex]
G2: [tex]76.6=V_0(6.725853664)+\frac{1}{2}a(6.725853664)^2+250[/tex]
E2: [tex](11.3889)(6.725853664)=V_0(6.725853664)+\frac{1}{2}a(6.725853664)^2+250[/tex] since both equations are equal.
Now, using both E1 and E2, I solve for [tex]a[/tex] in E2, and then plug it into E1 to obtain [tex]V_0[/tex].
[tex]a = \frac{(11.3889)(6.725853664)-V_0(6.725853664)-250}{\frac{1}{2}(6.725853664)^2}[/tex]
[tex](6.3889)(7.278260871) =V_0(7.278026081)+\frac{1}{2}\left ( \frac{(11.3889)(6.725853664)-V_0(6.725853664)-250}{\frac{1}{2}(6.725853664)^2} \right )(7.278026081)^2+250[/tex]
[tex]V_0=0.7698312727\frac{m}{s}[/tex]
Now I stopped here because I find it very hard to believe that the car is traveling that slow, so I feel that I've set something up wrong. Have I? Or is that the actual initial velocity, and I'm over analyzing it?
Thanks!
Looks like you're over-analyzing things a bit. Your R1/R2 and E1/E2 equations serve no purpose, as far as I can see. (You already found the times.)
The only equations you need to solve together are G1 and G2. Solving them I get a similar answer for V0 (not exactly the same, but close enough).
I went on ahead with what I had and got it wrong. But the second time around (it gives you new values), I concentrated on the green car, and only used the red car to get the time, and I got the correct answer.
Thanks for your help! :biggrin:
FAQ: Constant Acceleration involving two identical objects
What is the definition of constant acceleration?
Constant acceleration is the rate at which an object's velocity changes by the same amount over equal intervals of time. This means that the acceleration remains constant, or does not change, throughout the object's motion.
How is constant acceleration calculated?
Constant acceleration can be calculated by dividing the change in velocity by the change in time. This can be represented by the equation a = (vf - vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
What is the difference between constant acceleration and uniform motion?
Constant acceleration involves a change in velocity over time, while uniform motion involves a constant velocity. In other words, an object experiencing constant acceleration will have a changing speed, while an object in uniform motion will maintain the same speed.
What is the significance of two objects having identical masses in a constant acceleration scenario?
In a constant acceleration scenario involving two identical objects, the force applied to each object will result in the same acceleration. This is because the mass of an object is a factor in determining its acceleration, and with identical masses, the force will have an equal effect on each object.
What are some real-life examples of constant acceleration involving two identical objects?
One example of constant acceleration involving two identical objects is a race between two cars with identical engines and weights. As both cars accelerate at a constant rate, they will have the same final velocity at any given time. Another example is a pair of objects falling from the same height under the influence of gravity, as they will both experience the same acceleration due to their identical mass.
