Constant Acceleration/Velocity HW question
  • Thread starter jessedevin
  • Tags
    Constant
In summary, the problem involves a car and a cyclist traveling in adjacent lanes with different constant accelerations. The goal is to find the time interval in which the bicycle is ahead of the car and the maximum distance by which the bicycle leads the car. The solution involves setting the position functions for each vehicle equal to each other and solving for time. It is necessary to consider whether the car is still accelerating when the two vehicles cross paths. The final equations can be used to solve for the time and position at which the crossover occurs.
jessedevin
66
I am having trouble with this question. Please help!
As soon as traffic light turns green, a car speeds up from rest to 50.0 mi/h with constant acceleration of 9.00mi/hr*s. In the adjoining bike lane, a cyclist speeds up from rest to 20.0 mi/h with constant acceleration of 13.0 mi/hr*s. Each vehicle maintains constant velocity after reaching its cruising speed.
(a) For what time interval is the bicycle ahead of the car?
(b) By what maximum distance does the bicycle leads the car?
xf=xi + vx*t
vxf= vxi+ax*t
vx,avg= (vxi +vxf)/2
xf=xi+1/2(vxi +vxf)*t
xf=xi+vxi*t+1/2a*t2
vxf2= vxi2+2*a(xf-xi)
Im sorry but i have tried every way I can think but I keep on getting the wrong answer. I am completley stuck!
You don't have to give me the calculations, but just tell me your thought process to get the answers.
The answer in the back of the book (a) 3.45 s and (b) 10.0 ft
Please help.
Thanks!
Hi jessedevin,
Please post your thoughts on this problem and your work that was giving you the wrong answer.
alphysicist said:
Hi jessedevin,
Well, i know that we have to find where the bicycle and car cross paths, and to do that we have to set there position functions equal to each other. The problem is that I have no clue how to do that. Can someone help me out?
okay i tried doing it again, but i got the wrong answers. Heres what i did:
I used the formula xf=xi+vxi*t+1/2a*t^2, because there is a constant acceleration. I used that formula plus the constant velocity formula xf=xi + vx*t for the bicycle numbers and set it equal to the constant velocity + constant acceleration formulas for the car numbers, and solved for t. But I have no clue if its right. Can anyone help?
Why don't you start out by figuring the things you can?
How long does it take the bikeguy to get to speed? The car?
Where will they be when they reach constant velocity? These answers will help you figure out what to calculate next.
Flesh it out a bit with the numbers. Sometimes just explaining it helps you to understand it better.
heres what I did:
postion of car xf =xi+vxi*t+1/2a*t2 t<T
xf =(xi+vxi*t+1/2a*t2) + (xi + vx*t) t>T
position of bicycle is the same.
I am assuming that the bicycle and car intersect aft t>T, so i used the second formula for xf
Now with numbers
xf,car = xf,cycle
0 + (0)t + 1/2(9)t2 + 0 + 50t = 0 + (0)t + 1/2(13)t2 + 0 + (20)t
t = 15 s, which is way wrong, so i need help.
No one can help me out? Not even how to start?
I thought I gave you some pretty good hints. Figure it out a step at a time.
Let me get you started. How far from the start is he just starting to go at top speed? Would that be v2/2a = 202/2*13 =15.38m from the start? How long to get to speed? V/a = 1.538 secs
Now you have an equation for the BikeGuy's position as a function of time - after he has gotten to speed - for it must be after he gets to speed since he accelerates faster than the car.
X = 15.38 m + 20 (t + 1.538)
Next write an equation for the car's location as a function of time, after determining whether the car is still getting to speed when they pass or whether the car gets to speed before passing. (Figure the car's time to speed and distance to speed as a check.)
Then you can solve for the case where the car is accelerating, and if the time is greater than the time to get to speed then you must make another equation that takes that into account.
When their positions are equal - set one equation equal to the other, you will have an equation that you can solve for the Time to Passing.
Plug that back into either equation to figure the position.
Im sorry but I am still confused. I am up to you until we have to write the equation for the position of the car ( I did the previous calculations by myself, and I got the same results). How do you figure out if the car is still getting to speed when they pass or whether the car gets to speed before passing? This is the part the I was confused on since the beginning. I'll show you what I did, but I already know its wrong:
After finding t=1.54 sec, I found the cars velocity at that time:
vxfcar= 0+(9)*(1.54)= 13.9 mi/hr
Then I found the position of the car using the velocity:
xfcar=xi+1/2(vxi +vxf)*t
xfcar= 0 +1/2(13.9)(1.54)=10.7 mi
Then I found the velocity of the car to get to 15.4 mi by using:
vxfcar2= vxi2+2*a(xf-xi)
vxfcar2= (13.9)2+ 2(9)(15.4-10.7)
vxfcar= 16.7 mi/hr
Then I found the time to get to that velocity by using:
vxfcar= vxi+ax*t
16.7= 0 + (9)t
t=1.85sec
Then I added the two times and I got ttotal=3.4, but I'm pretty the way I got the answer is not the same way you described. And I do not know how to find the distance the bike lead, even though I know you have to change the units because the book decribes the car in miles but the answer is in feet!
PLEASE HELP ASAP! I need to figure this out by the end of the weekend!
vxfcar= 16.7 mi/hr
vxfcar= vxi+ax*t
16.7= 0 + (9)t
t=1.85sec
Sorry, I didn't notice it was mi/hr. That changes the numbers, but not the method. To keep things simple then I would convert to ft/sec. Using 1.46666 as the easy conversion (5280/3600) and applying that to all the mi/hr I get
13 m/hr*s = 19.
9 m/hr*s = 13.2
20 m/hr = 29.3
50 m/hr = 73.3
13 m/hr*s = 19.
9 m/hr*s = 13.2
20 m/hr = 29.3
50 m/hr = 73.3
But I am still confused on your method on getting the time at which the bike leads and the distance during that time. Can you go over it once more. I really need to finish this problem before is due and I think this problem is just over my head.
Let me do it again. How far from the start is he just starting to go at top speed? Would that be v2/2a = 29.32/2*19. =22.64 f from the start? How long to get to speed? V/a = 29/19 = 1.54 secs
X = 22.64 f + 29 (t - 1.54) f
EDIT: It's (t -1.54) because the first 22.64 is accounted for in that first 1.54
x = 1/2 a t2 = 1/2 (13.2) t2 = 6.6 t2
Now set these 2 x equations = to each other.
Now the time for the car to get to speed is 50/13.2 = 3.78
So if it looks like it takes longer than that we need a new equation for the car.
I think you mean 73/13.2 =5.55s...
but I am think I know where you going with this. But I am still working on it
Absolutely right. I can't lose the old numbers no matter how hard I try it seems. Thanks.
You're not as lost as you were thinking at first then.
Okay so I did your method, but I modified some of your numbers to three sig figs...
So I set the postion formula for the bike equal to the position formula for the car:
6.60t2= 22.6 + 29.3(t-1.54)
t= 3. 45 s
Yes! I got that part, but how do I find the maximum distance the bike lead?
t= 3. 45 s
OK almost there then.
You have two equations of X. What is their difference? When was it at a maximum?
Happily the difference function is the Quadratic that you just solved. Where they meet is where that function was equal to 0.
But what you want now is where that function is at maximum. If you have a quadratic where is the maximum?
I have no clue? What do tou mean by the difference function?
Do you mean 0=22.6 +29.3(t-1.54) - 6.6t2
I guess then you find the maximum of this function by taking the derivative and setting it equal to zero to find the time where the velocity is 0. Then put that time into the difference function and that will give me the most distance the bike leads?
Yes and no.
I would state it more generally that:
ΔX = Xb-Xc = 22.6 +29.3(t-1.54) - 6.6t2
The question asked you to solve for when ΔX = 0. Which you did.
But now you want the maximum of ΔX and as you said you take the derivative ... That part you know what to do. I just wanted you to clearly understand why you can do that is all.
Good job.
LowlyPion said:
Yes and no.
Good job.
Thanks A lot. I really appreciate it. Good luck on all endeavors!
Related to Constant Acceleration/Velocity HW question
1. What is constant acceleration?
Constant acceleration is the rate at which an object's velocity changes over a certain period of time. It is the measure of how quickly the velocity of an object is changing, either increasing or decreasing, in a straight line.
2. What is the difference between constant acceleration and constant velocity?
Constant acceleration refers to the change in velocity over time, while constant velocity refers to the speed of an object remaining the same over time. In other words, an object with constant acceleration is either speeding up or slowing down, while an object with constant velocity is moving at a consistent speed.
3. How is constant acceleration calculated?
Constant acceleration can be calculated using the formula a = (vf - vi) / t, where "a" is the acceleration, "vf" is the final velocity, "vi" is the initial velocity, and "t" is the time. This formula can also be rearranged to solve for any of the variables.
4. Can an object have constant acceleration and changing velocity?
Yes, an object can have constant acceleration and changing velocity, as long as the change in velocity remains constant. For example, an object moving in a circular motion has a constant acceleration towards the center, but its velocity is constantly changing in direction.
5. How does air resistance affect constant acceleration?
Air resistance can affect constant acceleration by causing a decrease in acceleration. As an object moves through the air, air resistance creates a force that opposes the motion. This force can cause the object to slow down, resulting in a decrease in acceleration over time.
