Constant Acceleration Versus Coasting Conundrum
In summary: Space Probe A would cover 1.5AU in 54 hours, 2.5AU in 543 hours, and 1.25AU in the remainder of its journey. In summary, the space probe would cover the same distance in the same amount of time by accelerating and decelerating.
Dr Wu
176
41
A disclaimer: I'm trying to limit myself to asking questions on Physics Forums, partly because I feel I've gone way past my quota. Still, there is one question that simply won't go away, and it concerns the relative efficiencies between two forms of motion. The first involves continuous acceleration/deceleration; the second a far shorter, brisker spell of acceleration/deceleration linked by a period of inertial motion. Three assumptions must hold true: (1) distance (2) flight-time and (3) fuel use remain precisely the same in both modes of travel.
There's quite a lot of info about this subject on the net, but somehow I keep getting left behind. Also, there's a marked tendency to bring in Special Relativity, which adds a layer of complexity which I really can do without right now. Newton's Laws of Motion are plenty enough to be getting on with, at least for me. I've chosen space travel just to keep things as simple as possible. I've also tried working this out on the calculator pad - so much so that I don't understand anything at all now.
(Again) Many thanks.
Since you're assuming the same distance, time, and fuel usage in both situations, they would both be just as efficient.
The answer is - 'it depends'.
Consider a petrol car, the efficiency of it's engine varies with engine speed and throttle position, generally efficiency increases with both.
So a petrol engine is more efficient when under heavy acceleration (wide open throttle, high rpm) than light acceleration (partial throttle, low rpm).
So to get better fuel economy the engine must be kept closer to it's peak efficiency point, that is, use heavy acceleration. ( This is the approach hypermilers (extreme fuel economy enthusiasts) use).
A spacecraft doesn't use a petrol engine but rocket engines also have peak efficiency points, so whichever approach keeps the rocket closer to it's peak efficiency point will get better fuel economy. If you're not using a rocket then it depends on the efficiency characteristics of whatever engine you use.
There's a quota on how many questions you can ask at PF? Since when?
Flight time implies aircraft. Let's start with that assumption. We'll ignore relative wind effects because the aircraft will fly through them in either case. Whenever aircraft coast they lose altitude and forward speed. The faster they travel, the quicker they lose speed (increased air resistance). That's a lot of energy that has to be replaced by subsequent acceleration. In practice there is a range (somewhat narrow) of engine RPMs that produce the optimum in maintaining altitude and forward speed. It always works out to some narrow range of constant air speed. Too slow and the plane has to adopt a steeper angle relative to the direction of travel, increasing drag. Too fast and aerodynamic drag increases too much.
In cars, take a look at how modern cars with CVTs are programmed. Rarely will you ever see anything close to WOT conditions from the engine.
And no, hypermilers DO NOT use heavy acceleration unless they want to speed up. Accelerate/coast/accelerate/coast is very costly in fuel efficiency. They drive at as constant a speed as possible, coasting where practical. I'm pretty good at it, getting close to EPA mileage in the summer with the A/C going.
And no, Otto cycle engines are not most efficient at WOT. That's thermodynamic theory. In practice internal friction from a variety of sources quickly overcomes reduced pumping loads with a partially closed throttle.
I restricted myself to space flight in order to avoid frictional, gravitational and air resistence issues. It seems evident to me (now at least) that increased acceleration, while shortening a given flight-time, incurs the penalty of greater fuel use - although I do take onboard the proviso that certain engines may perform more efficiently at a higher work rate than a lower one. One unknown, of course, is applying this principle to an unknown quantity like (say) a nuclear fusion rocket. Supposing propellent wasn't an issue, I would imagine that such an engine would be several magnitudes more efficient than our current chemical powered rockets, although this is just a conjecture on my part.
As for the continuous acceleration/deceleration v accel/coast/decel conundrum, here's the results for some recent back-of-the-envelope calculations of mine.
Space Probe A (Mass 5 Tonnes) accelerates at 1.0g from zero to a velocity of about 1,900 km/s. This boost lasts for 54 hours, during which time it has covered a distance of 1.25AU. It then coasts for the next 543 hours, covering a distance of 2.5AU. It then decelerates at the same rate it did while accelerating. The totals are as follows: Distance = 5AU. Time = 650 hours (27 days). Energy requirement = 0.018 EJ.
Space Probe B (Mass 5 Tonnes) accelerates at 0.5g from zero to a velocity of about 1,900 km/s. This burn lasts for 217 hours, during which time the probe has covered a distance of 2.5AU. It then turns round and decelerates at the same 0.5g rate. The totals here are: Distance = 5AU. Time: 434 hours (I8 days). Energy requirement: 0.018 EJ.
Summary: distance and energy remain the same. What is different, however, are the two flight-times. Space Probe B takes 66% more time to cover the 5AU distance than Space Probe A, despite having the same energy needs. Conclusion: Space Probe B is clearer the winner in terms of time saved - i.e. you get more bangs for your bucks with constant acceleration/deceleration.
I've yet to see if it's possible to replicate Space Probe B's stats using the accel/coast/decel flight method. This will be my next project.
Many thanks again :)
Correction: Space Probe A takes more time to complete the journey, NOT Space Probe B! My apologies.
One thing to consider is that the payload of craft B will be bigger as it's engine will have less mass.
I've been wondering about that for so long! I knew intermittent speeding was good somehow, but how does it affect fatigue life?
FAQ: Constant Acceleration Versus Coasting Conundrum
What is constant acceleration?
Constant acceleration is a type of motion where the velocity of an object changes by the same amount over equal intervals of time. This means that the object's speed is increasing or decreasing at a constant rate.
What is coasting?
Coasting is a type of motion where an object remains at a constant velocity, meaning that it is not accelerating or decelerating. This is often seen when an object is moving at a constant speed with no external forces acting upon it.
What is the difference between constant acceleration and coasting?
The main difference between constant acceleration and coasting is that in constant acceleration, the object's velocity is changing at a constant rate, while in coasting, the object's velocity remains constant. This means that in constant acceleration, the object is either speeding up or slowing down, while in coasting, the object maintains a constant speed.
What are some real-life examples of constant acceleration?
Some examples of constant acceleration in everyday life include a car speeding up or slowing down, a rollercoaster going up or down a hill, and a ball falling under the influence of gravity. These objects are all experiencing a change in velocity at a constant rate.
How can constant acceleration and coasting be used in scientific experiments?
Constant acceleration and coasting can be used in experiments to study the effects of different forces on an object's motion. By measuring the object's velocity and acceleration, scientists can determine the magnitude and direction of the forces acting upon it. This information can then be applied to real-world situations, such as designing safer cars or understanding the motion of objects in space.
