Luchekv
- 66
- 1
1. Homework Statement
A gas (treated as air) powered turbine provides power to a compressor which then sends the compressed air through an intercooler (heat exchanger).
Turbine:
Gas enters @ 0.03kg/s, 370 degrees Celsius
Gas leaves @ 300 degrees Celsius and a "lower pressure"
Compressor:
Draws fresh air @ 0.015kg/s, 30 degrees Celsius, 100kPa
Air leaves at a "higher pressure"
Heat exchanger:
The intercooler cools the compressed air down to 70 degrees celsius
Ambient air flowing through/across the intercooler is @ 30 degrees Celsius, 100kPa
Ambient air leaving the intercooler is @ 60 degrees Celsius
Q1.) Calc Power output of turbine. Constant avg spec heats Cp=1.005 @ 300K
Q2.) Calc temp of air leaving compressor. Const avg spec heats Cp = 1.005 @ 300K
Q3.) Calc mass flow rate of the ambient air leaving the intercooler (not the compressed air going to the engine) - Use variable spec heats for extracted from tables
2. Homework Equations
Q*-W*=m*[h2-h1+(V22-V12)/2+g(z2-z1]
Δh=Cp(T2-T1)
3. The Attempt at a Solution
Q1.) -W*=m*[h2-h1]
First I found Cp at Tavg=335 Celsius or 608K..Cp=1.05324
So then
-W=m*(Cp(T1-T2))
-W=0.03(1.05324(370-300) =2.2118Watts
Q2.)
-W*=m*[h2-h1]
-W=m*(Cp(T2-T1))
2.2118=0.015(1.005(T2-30C)
T2= 176.72 Celsius
Q3.) I'm absolutely stumped with this one..Ive gone to the "Ideal-gas properties of air" table in the book and picked the enthalpy values for T1 and T2...but don't know where to go from there.
I know I'm lacking with units, just focusing on the method and will go back and straighten that out after.
Turbine:
Compressor:
Heat exchanger:
Δh=Cp(T2-T1)
Q1.) -W*=m*[h2-h1]
So then
-W=m*(Cp(T1-T2))
Q2.)
-W*=m*[h2-h1]
-W=m*(Cp(T2-T1))
T2= 176.72 Celsius
