Constant Current Source for high current
In summary: I remember the voltage doubler I used.In summary, he can add a capacitor to the end of the dynamo to make a constant voltage source for his cycling lights.
Akmalidin
69
Hi,
I am building a charger for my bicycle front and tail light that uses dynamo to charge them while cycling.
However, depending on my speed, current is fed differently to lights and they start to flicker. Therefore, I was wandering if there is a way to make a constant current source which outputs around 1A regardless of my dynamo circulation speed?
Use your dynamo to charge a battery of the correct voltage and run your lights off the battery.
Likes cnh1995 and davenn
I think you will like the result of just adding a capacitor
I don't think a capacitor will work because the dynamo gives AC.
To charge a battery is a good idea but will require a rectifier to obtain DC. For battery charging purposes, a smoothing capacitor will increase the charging voltage. Also, remember that a rectifier drops some voltage - maybe 0.7 volt.
Likes cnh1995
A dynamo is a DC generator
If it was AC it would be an alternator
A capacitor is a very easy fix for his light. I have done this myself when I was a kid. I tore it out of a smashed tv
Likes cnh1995
I agree with you that "dynamo" means a DC generator, but I have always found that the ones used on bicycles are AC.
The lamp only needs to have a roughly constant voltage supply .
The output voltage of most cycle dynamo's is usually too low at slow speed and too high at high speed .
Can't do much at the lower end except by using a storage battery system but at the high end you can just clip the voltage .
You can do this with a simple circuit employing Zenner diodes .
Likes cnh1995
Andy SV said:
Well than he can make this then
https://en.m.wikipedia.org/wiki/File:Diode_bridge_alt_1.svg
You can add the cap to the end of it
With that... it will not matter if it's A.C. D.C or Led Zeplin it will just work
My only doubt is that the full wave rectifier involves two diode drops of 0.7 volt each. I think if I wanted to try charging a little battery, I would try a voltage doubler rectifier circuit.
For Electrical Engineers that's true but everyone with a bicycle uses a 'Dynamo" which has a rotating magnet and coils in some arrangement.
I remember reading (perhaps an A level exercise?) that the series inductance of the stator coil of a (bicycle) dynamo gives a certain amount of regulation of output Volts by adding reactance in series which increases with frequency. It would need to be matched to the bulb being used. This was in the days of filament lamps, of course.
Nowadays, there is plenty of power to spare for driving LED lamps so efficiency wouldn't be as much of a problem. Driving a filament bulb of only a few Watts used to be hard work, I remember. A very low capacity rechargeable battery would be more than adequate. The only trouble would be in making a safe (AC to DC, of course) charging circuit for a Lion (say) battery that would not compromise the battery life nor blow it up.
Try a cycling forum for some ideas, perhaps.
You might be amused that as a boy of about 15, I tried to use my bicycle dynamo to light the filament on a receiving tube (type 955) for a VHF receiver. It failed, not enough power.
Likes Averagesupernova and sophiecentaur
You can get silly levels of power from a bike dynamo if you put an 8 inch three blade hobby prop on the end of it and hold it out a car window on the highway.
And you are putting "silly levels of Power" in, compared with what a cyclist achieves - even on a good day.
I wonder how long a bicycle dynamo would work for, under those conditions, before its bearings or windings packed up.
Andy SV said:
Well I got tired of playing with it before I noticed any degradation but I probably held it out the window for a couple hours.
These folk have some interesting things to say on the subject
http://electronics.stackexchange.com/questions/47226/using-leds-in-a-bridge-rectifier-circuit
Of course, somebody was paying for that power in the form of extra fuel to push the car along the road against the extra load.
Also, I would want my dynamo to work of a lot longer than just a few hours. But I'm stingy like that. :wink:
Wikipedia says
A small electrical generator built into the hub of a bicycle wheel to power lights is called a hub dynamo, although these are invariably AC devices,[citation needed] and are actually magnetos.
https://en.wikipedia.org/wiki/Dynamo
Indeed , what you describe has the name "Synchronous Impedance" and is characteristic of an alternator. Current in the armature coils makes MMF that opposes MMF from field, preventing further voltage increase. It's called "Armature Reaction" .
Big machines put a number on it called "Short Circuit Ratio" which is simply how much current the machine delivers into a short circuit with rated excitation.That much armature current cancels all the field MMF.
Likewise for a little permanent magnet machine, there is some value of armature current that'll exactly cancel all the permanent magnet field MMF leaving terminal volts at zero.
A little less current will leave some terminal volts to drive a lamp load.
By balancing strength of the rotating permanent magnet field against number of turns in armature the designer can arrive at fairly constant current output over a reasonable range of speed.
If OP changes his load from incandescent to LED and adds rectifiers he'll change the operating point away from what designers chose, , probably to significantly higher RPM . He might have to spill current to hold volts down.
would be an interesting experiment.
Likes cnh1995 and sophiecentaur
Use a single diode for a half wave rectifier and a low value resistor to charge the battery. The battery itself will act as a zener to keep the voltage relatively constant.
Likes cnh1995
Yep. Far more able to maintain its own volts than a regular Zener.
Likes cnh1995
Related to Constant Current Source for high current
1. What is a constant current source?
A constant current source is an electronic circuit or device that provides a steady and consistent current output, regardless of changes in the load or input voltage. It is commonly used in electronic devices to ensure that a specific amount of current is always supplied to the circuit.
2. Why is a constant current source important for high current applications?
A constant current source is essential for high current applications because it helps to prevent damage to the circuit or device. High currents can cause overheating and burning of components, but a constant current source ensures that the current remains at a safe and controlled level.
3. How does a constant current source work?
A constant current source typically uses a feedback mechanism to maintain a steady current output. This feedback can be achieved through various methods, such as using a transistor, op-amp, or a voltage regulator. The circuit adjusts the voltage across the load to maintain a constant current, even if the load resistance changes.
4. What are the applications of a constant current source?
Constant current sources are used in a wide range of applications, including LED lighting, battery charging, laser diode drivers, and electroplating. They are also used in research and testing, such as in fuel cell testing and chemical analysis.
5. How do I choose the right constant current source for my application?
The right constant current source for your application depends on factors such as the required current range, input voltage, load resistance, and accuracy. It is essential to consider these factors and choose a source with the appropriate specifications and capabilities to meet your specific needs.
  • Electrical Engineering
23K
