Constant pressure heat of reaction -> constant volume q
In this case, since there are 33 moles of H2 on the reactant side and 33+16=49 moles of H2O on the product side, the change in moles is 49-33 = 16. Therefore, we use -16 as the value for Δn.
jybe
41
For the reaction below, the constant pressure heat of reaction is qp = −3256 kJ mol−1 at 25 °C. What is the constant volume heat of reaction, qV , at 25 °C?
16 CO(g) + 33 H2(g) ⟶ C16H34(l) + 16 H2O(l)
Enter your answer in kJ mol−1, rounded to the nearest kilojoule.
At constant pressure, the heat of reaction is equal to the enthalpy change
At constant volume, the heat of reaction is equal to the internal energy change: ΔH = ΔU + ΔnRT
ΔU = ΔH - ΔnRT
ΔU = -3256kJ/mol - ΔnRT
Edit:
ΔU = -3256kJ/mol - (-49)(8.314x10^-3)(298.15)
ΔU = -3135 kJ/mol
Have I done it correctly?
Chestermiller said:
It looks correct to me.
I was wondering about the -49 used for ##\Delta n## -- what is the reasoning ?
It's the change in moles of gas gathered from the equation, used to calculate work done
Related to Constant pressure heat of reaction -> constant volume q
1. What is the difference between constant pressure heat of reaction and constant volume q?
The constant pressure heat of reaction is the amount of heat released or absorbed during a chemical reaction that is carried out at a constant pressure. Constant volume q, on the other hand, is the amount of heat released or absorbed during a reaction that is carried out at a constant volume. In other words, the difference lies in the conditions under which the reaction is taking place - either at a constant pressure or a constant volume.
2. How are constant pressure heat of reaction and constant volume q measured?
Constant pressure heat of reaction is typically measured using a bomb calorimeter, which is a device that allows for the reaction to take place at a constant pressure. Constant volume q can be measured using a bomb calorimeter as well, but it can also be measured using a vessel with a fixed volume, such as a sealed container.
3. Why is it important to know the constant pressure heat of reaction and constant volume q?
Knowing the constant pressure heat of reaction and constant volume q can provide important information about the energy changes that occur during a chemical reaction. This information can be used to determine the thermodynamic properties of a substance, such as its enthalpy and entropy, which are crucial for understanding and predicting the behavior of chemical systems.
4. How does the constant pressure heat of reaction and constant volume q affect the equilibrium of a reaction?
The constant pressure heat of reaction and constant volume q can affect the equilibrium of a reaction by influencing the direction in which the reaction proceeds. In a constant pressure system, an increase in heat of reaction will favor the products, while a decrease in heat of reaction will favor the reactants. In a constant volume system, the equilibrium will shift in the same direction as the heat of reaction, but to a lesser extent due to the fixed volume.
5. Can the constant pressure heat of reaction and constant volume q be negative?
Yes, both the constant pressure heat of reaction and constant volume q can be negative. A negative value indicates that the reaction is exothermic, meaning that heat is released during the reaction. This can occur when the energy of the products is lower than the energy of the reactants, resulting in a negative change in enthalpy.
13K
