Constant Velocity : Does it means objects is at Rest
In summary, the conversation discusses the concept of velocity and how it relates to displacement and time. It clarifies that a constant velocity does not mean the object is at rest, but rather that the rate of change in displacement over time remains the same. The confusion arises when the definition of velocity is not strictly adhered to and misleading language is used. The displacement vs time graph in this scenario would be a straight line with a slope equal to the velocity.
PrakashPrasad
I have been studying that velocity = displacement / time.
Now what if displacement / time always gives me same value - does it means that object is at rest as displacement is same then the body has not moved at all.
So in above graph velocity is constant - ie displacement wrt to time is same - so if displacement is same it would mean that object hasn't moved
In other word constant velocity does it means displacement remains the same wrt time which then would mean that object is at rest
The displacement is not the same--the object is moving! What remains the same is the velocity, the rate at which the displacement changes.
Likes PrakashPrasad
Such confusion usually arises because of not adhering strictly to a definition, and using misleading language. You first stated, correctly, that velocity = displacement / time, and then went on to say, incorrectly, that it is displacement WRT time. I do not know what that means! Velocity is always displacement / time, so if the velocity is constant, that means displacement / time is constant. Then the displacement is constant velocity multiplied by time, so it is not constant. The displacement vs time graph in this case is a straight line with a slope equal to the velocity.
Related to Constant Velocity : Does it means objects is at Rest
1. What is constant velocity?
Constant velocity refers to the movement of an object at a consistent speed and direction. This means that the object is not accelerating or changing its direction.
2. Does constant velocity mean that an object is at rest?
No, constant velocity does not necessarily mean that an object is at rest. An object can have a constant velocity while still moving at a non-zero speed. However, if an object has a constant velocity of 0, then it is considered to be at rest.
3. How is constant velocity different from average velocity?
Constant velocity is when an object maintains the same speed and direction over a period of time, while average velocity takes into account the total distance traveled and the total time taken. Average velocity can change if the speed or direction of the object changes, while constant velocity remains the same.
4. Can an object have a constant velocity if it is accelerating?
No, an object cannot have a constant velocity if it is accelerating. Acceleration is a change in velocity, so if an object is accelerating, its velocity is changing. Therefore, it cannot have a constant velocity.
5. How is constant velocity related to Newton's First Law of Motion?
Constant velocity is directly related to Newton's First Law of Motion, which states that an object in motion will remain in motion with a constant velocity unless acted upon by an external force. This means that if an object has a constant velocity, it will continue to move at that speed and direction unless an external force acts upon it and changes its motion.
  • Mechanics
  • Mechanics
